584,837 active members*
5,677 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > DC DRIVE UPGRADES for SHOPTASK/SHOPMASTER
Page 1 of 2 12
Results 1 to 20 of 33
    Dec 2007
    413
    I spoke to JT yesterday and he is preparing some possible upgrades for all the machines. One is a DC drive system to replace the AC motors and all the belt mechanisms for changing speeds. Another is a stepper driven power feed unit that can cut threads and upgrade all the old machines to 3 axis power feed.
    Jul 2005
    151
    Quote Originally Posted by sharpshooter90 View Post
    I sent them an e-mail- I am thinking of the Stepper system for my quadra lift if the price is reasonable.
    Dec 2007
    413
    I went ahead and ordered the DC system for my Patriot. I got the controller, switches and speed pots by mail in 2 days. The motors should arrive next week. JT also sent me an instruction file on how to drill the new mounting holes for the motors. He included the drill and tap as well. Today I plan to work on mounting the control board and the other controls. I removed all the old belt change stuff, and let me tell you, its about 75# worth of mechanism that you no longer need. Attached are some pictures of the progress so far. Once the motors arrive I will post the mounting and how it all works.
    Attached Thumbnails Attached Thumbnails DC DRIVE 9.jpg   DC DRIVE 10.jpg   DC DRIVE 11.jpg
    Nov 2007
    277
    The problem with DC motors are that they are expensive and heavy. Three phase motors with a VFD drive are very light cheap by comparison. The VFD drive is the expense. Unless you are threading something which you don't do very often it has no benefit above 500 rpm.
    Sep 2004
    144
    Your using the same control I'm using on mine I see. Recommend adding some kind of air flow(fan) to cool the controller. (I used 2 35mm 12volt dc fans) Gets hot on long run time. Also if your using the same motor as I did. Recommend adding some kind of fan to that. I'm using a 120mm 120cfm 110ac fan. These motors weren't designed to run for long periods with out some time of cooling.
    http://www.rainman229.com
    Dec 2007
    413
    Thanks- According to the instructions, there are 2 cooling fans in the set- 1 for each motor, but no mention of a fan for the control board. The patriot has 2 mounting holes in the housing for fans, so maybe I will get some for the board as well. I'm anxious to get the set up and running, what is your opinion of the torque etc on these drives.
    Sep 2004
    144
    They have plenty of power. Keep in mind they don't like get wet. I'm only running the mill with dc motor. Don't use the lathe on mine often enough to justify a dc motor.
    Dec 2007
    413
    Rain-
    A couple of changes in my program. On the advice of some other shoptask owners, I decided to go with the Minarik controller. It has a lot of features including dynamic braking and can run off 220 volt power. I ordered 1 controller and will run it on 220 volts and pull a 110 leg off that to run the original controller. After I compare the performance I can decide whether to go with 2 Minariks. On your advice I also ordered a couple of cooling fans for the CNC housing. The patriot has 2 mounting places already in the housing for cooling of the CNC and I found 2 fans for 7.00 each that fit. I got my motors and other fans yesterday. The motors came with pulleys installed - 2" for the lathe and 2.5" for the mill. They bolted up in a snap. Got them mounted and belts installed and adjusted. I also followed the wiring diagram JT sent me and have the DC wires using spade connectors and the 110 volt wires using bullet connectors so there is no chance of mixing them up. The motors are USA made and are surprisingly small, but rated at 2.25 HP . They also have a thermal overload switch. Today's plan is to get the motor cooling fans mounted.
    Attached Thumbnails Attached Thumbnails DC DRIVE 12.jpg   DC DRIVE 13.jpg   DC DRIVE 14.jpg   DC DRIVE 15.jpg
    Dec 2007
    413
    A couple more pictures
    Dec 2007
    413
    I did a little more last night and this morning. I though about a number of options for the fan mounting. I wanted them to blow past the pulley through the motor to help keep stuff from being pulled into the open end. I don't think the mill is any real problem because it sits vertical and well above any cutting. The lathe would be subject to chips and fluids from a coolant system, so I plan to make up a cover for it as well. Anyhow, after some looking and pondering, I decided to mount the mill fan inside the top cover just over the motor end. There is just enough room to clear all the mechanisms. On the lathe I decided to put the fan on the door. I wavered around a bit because both places required cutting a hole in the parts and its a new machine. Finally I kicked myself into gear and layed out the holes and used a 4" hole saw to cut the holes. Mounted the fans and ran the wires and tested out the openng and closing of the covers. Everything works and fits nicely. Watch out though- the hole saw makes a razor sharp edge on the sheet metal and I now have a nice band aid on my finger to prove it.
    :violin:
    Attached Thumbnails Attached Thumbnails DC DRIVE 20.jpg   DC DRIVE 21.jpg   DC DRIVE 22.jpg   DC DRIVE 23.jpg
    Dec 2007
    413
    Kicked around the idea of a lathe motor shield for a while and tried to make one out of some old sheet metal. I don't have a shear or break, so I was bending the stuff over the edge of the bench and rivetting the corners together- by the time I finished it look like c*ap. Then I noticed the CNC drive cover for the Z axis was almost identical to what I was making. I pulled it off and it fit like a glove- all I needed to do was drill 2 holes. JT said he had one in stock and the price was cheap, so he is sending one to replace mine. I drilled it out and sprayed it black to match the motor mount. I just need to get a rubber grommet to plug the hole where the acme screw goes through.
    Dec 2007
    413
    A further update on the controllers- I ran the motors- one off the original controller and one off the Minarik. I can't tell too much difference without some sort of dynamometer test, but I feel the Minarik is putting out more torque. This may be due to the fact that it has the load compensation adjustment. I am going to order one more before buttoning the whole thing up.
    Dec 2007
    413
    Latest news-
    I got my second Minarik controller and the 2 small fans yesterday. I mounted the controller in the CNC enclosure and also the 2 fans. The enclosure has 2 holes surrounded by 4 mounting holes which are the standard size for all the computer style " muffin" fans. These fans can be bought for a few dollars in various voltages from 12 V DC to 115 V AC. Installation only took a few minutes and looks nice with the chrome grilles attached. I put the fans in with the air flowing from the outside to the inside of the enclosure. My thinking being that it will sort of pressurize the box and keep any dust and dirt out. I paid an extra 50.00 for the heat sinks for the Minarik, but I think I could have skipped that expense with the fans providing all the cooling necessary. I hope to get everything done this weekend and report on the results.
    Attached Thumbnails Attached Thumbnails DC DRIVE 25.jpg   DC DRIVE 29.jpg   DC DRIVE 26.jpg   DC DRIVE 30.jpg
    Dec 2007
    413
    Got every thing put together this morning and tested the motors and controllers. I left about 12" of wire from my front panel controls to the controllers, but found it was not real convenient for the adjustments. There just wasn't enough cable length to set the front panel down and do the adjustments on the controllers. If you leave 18" of cable, you can clamp the front panel to the mill cover and run the potentiometers with one hand and adjust the controller with the other. The motors are rated at 130 volts and the controllers have a selector for 90 or 180 volts. I chose the 180 setting. Be careful with the max speed, torque and IR adjustments, because if the motor gets full 180 voltage it will really spin and get hot. My fan arrangement worked good,as I left the fans running after adjusting everything and they cooled the motors down in a couple minutes. It sure is nice to just twist that knob and adjust the speeds. Speaking of that, I also screwed up on the hole locations for my knobs. The hole for the AC on off toggle was too close to the bottom, leaving only about 1/2" from the contacts to the bottom of the case. The 2 potentiometers should have been spaced wider also, as the large knobs I bought for them were too close together. I took my hot glue gun and covered all the terminals to be sure there was no chance of a short. Later today or tomorrow i'm going to do some cuts to test the motor torque at low speeds.
    Mar 2008
    3655
    What is the number of that minarik controller please?
    CR.
    Dec 2007
    413
    Crevice-
    The Minarik part # is MM2301C-000D
    Dec 2007
    413
    Update-
    I tried some cuts on CR steel this morning. At the higher speeds it seemed to be fine, running smooth with a minimum of slowdown in the spindle- you can see the torque compensation kicking in. However, at the low speeds it just doesn't have the " grunt" of the old AC motors running through the belt reduction. I think I may have screwed up on the controller adjustments. I sort of did them in a random fashion, and I think it may be necessary to do it in the order shown on the instruction sheet. I may not have my max torque setting up to its full value. I might pull my cover back off and fiddle around with it, or just wait until tomorrow and call Minarik for some help.
    Mar 2008
    3655
    Crevice-
    Thanks Sharps! I appreciate the info. What is brand and part number of motors please?
    CR.
    Dec 2007
    413
    Crevice,
    The manufacturer is Argord corp. out of Toronto. Model P140B
    Oct 2003
    927
    Crevice-
    Hi there!
    I did a search for that drive model and can't get any results.
    Just checking if the numbers were posted correctly.
    I went to several minarik drive dealers and none list that model.
    ..by the way, thank you for sharing!!!
Page 1 of 2 12
  1. Shoptask lath drive train replacement
    By kb7vms in forum Shopmaster/Shoptask
    Last Post: 09-21-2022, 02:49 PM
  2. Shopmaster confusion
    By truckmann4x4 in forum Shopmaster/Shoptask
    Last Post: 09-24-2008, 12:33 PM
  3. New Shopmaster. What to do 1st.
    By hgporter@porter in forum Shopmaster/Shoptask
    Last Post: 09-10-2008, 04:51 AM
  4. Need to buy a shopmaster for ductwork
    By dlemay in forum Bending, Forging, Extrusion...
    Last Post: 04-03-2007, 05:51 PM
  5. What motors with shopmaster
    By mysterious in forum CNC Machine Related Electronics
    Last Post: 02-23-2004, 10:10 PM
