585,932 active members*
3,827 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Need suggestion what software or cam or ??? to use with lathe/turntable
Results 1 to 5 of 5
    Dec 2004
    312
    I'm retrofitting a croma 4x8x4 hot knife cnc and im going to add lathe (5th axis) while im retrofitting it and using g540 from geckodrive (parallel port)
    i dont mind using mach or something but i would need some decent software to be able to produce gcode or a foam cutting software that will work with parallel port
    Any suggestion or input would be appreciated
    Dan Braun
    Dec 2007
    496
    Try Dolphin cad cam. Ive been using for quite some time now and have nothing but good things to say about it. Another suggestion is surfcam but that can be very costly.
    Dec 2004
    312
    okay will look into it.. (i rather mach myself since its very nice controller software)
    thanks for quick reply.. if anyone else has other suggestion im still open to options
    Cheers
    Dan
    Dec 2004
    312
    Quote Originally Posted by DanOSB View Post
    i know that mach is controller software(using it for my cnc router) love all of the options/features that mach can support.. but for hot wire foam cutting is a whole new world for me i have no experience on it.. i can build the table to make it move where i want it to move but for designing part i have no idea (im a 2.5 d guy and want to make bottles or columns or bunch round parts out of cnc foam cutter
    Cheers
    Dan
    Dec 2007
    496
    Mach 3 is a controller software. It is not cad cam.
  1. turntable for welding
    By DanOSB in forum MetalWork Discussion
    Last Post: 07-21-2009, 03:18 AM
  2. connecting turntable
    By pedroenrique in forum CNC Wire Foam Cutter Machines
    Last Post: 12-01-2008, 12:17 AM
  3. Cam software suggestion
    By fidia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-09-2007, 04:56 PM
  4. Replies: 17
    Last Post: 07-16-2006, 11:40 AM
  5. help with turntable
    By tallwelder in forum Welding Brazing Soldering Sealing
    Last Post: 05-19-2006, 08:12 PM
