585,744 active members*
4,944 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Please help a blind man.
Results 1 to 6 of 6
    259
    Problem,
    I have V9 on one machine and 10 on another and both do this.
    Partmaster level 3 Pro or what ever.
    When I open Dcam on the right hand side it opens up with the black command window displayed with the Status window behind it.
    As I don't use the Command window I have to select Status every time and it annoys me.
    In V8 there was a command somewhere on the menus to tell it to start in Status but in both V9 and V10 I can't find it. Any clues lads and lasses ? if not anyone have a decent guide dog ?
    John S.
    Oct 2006
    975
    Unhappy
    I don't see it either John. All I can find is the Status Bar in the View, Toolbars menu, but you are referring too the Tool Status Panel right? I wasn't even aware that option was available. Sorry no help from me.
    Regards,
    Regards,
    Wes
    Nov 2008
    18
    Yeah, it annoys me to. I can see no point to this command window in level 3 pro or whatever, it just adds confussion.
    I never even saw it in V8 so have just checked the printed help manual for V8& yep it is there, so there must have been a way to hide it.
    Nov 2008
    18
    Angry
    Hey, I have just found you can click the little 'x' at the top of the command/status/variable window and you can close the whole darn thing down & so get a bigger part display.
    However this totally screws up cam, even after re-booting I can no longer do anything. Cam opens however none of the toolbar icons do anything, file/open would be a good one to start with! Will not work if I come in via cad either. There does not seem to be a way to get the window to appear again.
    My cam is now totally stuffed (
    Thanks blind man !!!
    Anybody else want to try?
    May 2007
    428
    To fix this, go to "My Computer", "C-Drive", "Program Files", "Dolphin CAD/CAM",
    "Partmaster", "Programs", and the click on "Toolbar Fix.exe". Select "Restore"
    Dolphin CAD/CAM Support
    Nov 2008
    18
    Thanks for the tip, will try it tonight.
  1. blind hole, custom drill
    By kendo in forum MetalWork Discussion
    Last Post: 12-09-2008, 10:40 PM
  2. Screen viewer for deaf/blind?
    By MrWild in forum LinuxCNC (formerly EMC2)
    Last Post: 09-16-2008, 03:59 PM
  3. Blind Tapping
    By tikka308 in forum MetalWork Discussion
    Last Post: 04-04-2008, 04:47 AM
  4. Blind Teeth or so they are called
    By pinguS in forum MetalWork Discussion
    Last Post: 08-02-2006, 08:56 PM
