The latest release of Cnc Program Developer (2.1.0.6) is available.
The new release includes code macros for thread milling, boring and setting grid patterns for drilling and tapping with a corner origin.
The thread milling code macros allow you to produce the code for inside diameter and outside diameter. You can set the pitch, thread length, z depth to the bottom of the thread and a finish cut thickness.
CodeCam
Cnc Program Developer produces the code that gets run on the machine. You design with operations that have a one-to-one correspondence to a machining operation. You are machining the part in the design process with the code produced by the code macros.
The program is 3 axis (x, y, and z). Our structured cnc file format is both Haas and Fanuc compatible.
You can produce the code quickly and easily with our code macros. Code macros are available for:
- boring
- chamfering
- countersinking
- drilling
- milling - internally
- milling - externally
- peck drilling
- spot drilling
- tapping
- thread milling
More information, example videos and a trial are available at the web site:
Http://www.cncprogramdeveloper.com
The jpeg examples are the result of typical maching using Cnc Program Developer.
