584,866 active members*
5,141 visitors online*
Results 1 to 6 of 6
    Aug 2006
    118
    Tramming head on X3
    I've got a cnc X3 that I got running a month or so ago. It's been working pretty well but I still need to tram the head. I'm not sure how to do this. . .
    I've got a couple dial indicators but nothing thats made to mount to the spindle. Would getting an indicator like that (not sure what they are called) be a worth while investement? I know more or less how to measure how out of whack the spindle is, but I don't know how to compensate for it. I've got some shim stock. Do I put shims in where the column meets the base / head to column depending on where the compensation is needed? My CNC fusion conversion requires an aluminum brace inbetween the two. . .
    Adam
    Apr 2007
    126
    Quote Originally Posted by Thorpydo View Post
    Adam
    http://www.fignoggle.com/machines/x2...-tramHeadX.htm
    Jan 2009
    402
    Jul 2005
    969
    Quote Originally Posted by Matt McColley View Post
    google is sending a warning about accessing this site and eset nod32 is blocking it as contanning a trojan downloader i would advise not using this website as long as this matter is not settled
    eset smart security log:
    2009-02-10 14:30:50 HTTP filter file http://www.duwaynesplace.com/ HTML/TrojanDownloader.Agent.IJ trojan connection terminated - quarantined HPOFFICE\user Threat was detected upon access to web by the application: C:\Program Files\Mozilla Firefox\firefox.exe.
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Aug 2006
    118
    Tramming the head on an X2 in the x direction, with its swiveling column doesn't sound very difficult. It's when their isn't a straight forward means to adjust the axis.
    Mar 2008
    3655
    This is why SHIMS were invented.
    CR.
  1. tramming (X2)
    By isaac338 in forum Benchtop Machines
    Last Post: 11-02-2008, 06:09 AM
  2. Tramming CNC mill head: best tool?
    By struture7 in forum Calibration / Measurement
    Last Post: 10-04-2007, 11:09 PM
  3. Tramming the rigid ram head - how? Need to R&R...
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2007, 12:23 PM
  4. Tramming the ST mill head
    By dahui in forum Shopmaster/Shoptask
    Last Post: 03-24-2007, 09:29 AM
  5. Head Tramming question(s)
    By mxtras in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2006, 07:45 PM
