585,997 active members*
4,980 visitors online*
    Jan 2008
    18
    Complete Newbie Questions
    Been lurking around for a while and finally decided to start my first project. I want to start out simple by converting a small (8" X 8") cross slide to use on my bridgeport.
    Here's the plan:
    2 Keling KL23H284-35-4B 387 oz-in steppers
    Gecko G540
    Keling KL-350-48 48V/7.3A Power Supply
    I'm not planning to replace the lead screws with ball screws. Can I attach directly to the screws via couplings with these motors or should I compensate for not switching to ball screws by gear reducing the motor with 1:2 or 1:4 pulleys? Should I step up to the 495 oz-in motors and a bigger power supply? Am I even headed in the right direction with this setup? Not really worried about speed or accuracy so much as just getting my feet wet with this first project.
    Any help greatly appreciated.
    Mar 2008
    3655
    Hi gotfdirtball. I see you have been doing some homework. Nice first post and good parts selection!
    Ballscrews are usually 5 TPI. Depending on how much more than that your screws are, you may already be geared 2 or 3 to 1 by comparison. The 387s should be more than enough to direct drive an 8 inch table.
    You may have to lathe the ends of the screws to accept couplings or pulleys though.
    CR.
  1. OM newbie questions
    By emceul in forum Fanuc
    Last Post: 10-11-2006, 05:11 AM
  2. complete newbie with q's about hobby cnc order
    By rkremser in forum Hobbycnc (Products)
    Last Post: 03-26-2006, 05:17 AM
  3. Replies: 11
    Last Post: 03-13-2006, 03:23 PM
  4. Chopper for AVR from complete newbie, comments pls
    By genericuser in forum Open Source Controller Boards
    Last Post: 04-01-2005, 04:22 AM
  5. First post complete newbie
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 04-19-2004, 06:20 AM
