I read old thread about uhu ,seams here you are still writting about. I received this days controller from Uli , and pieces on reichelt .de . I have soldered two controller board{from 6}.,and just i expected after i readed many experience before me..... i neeed helpp.
1. i cant test uhu board .. dont know..maybe encoder ..i put on pc those 2 green led are shining, error led is ok vhen i put error on uhu soft control, is ok pc see my board but i cant move my motor ..sometimes he goes away alone in one direction.
motor for testing is shinano kenshi dx050..encoder 200lines 90degrees 2 chanel 4 wire { i have other bigger but encoder on them are not ok for uhu-3 wire max 50 lines.."} please tell me is encoder is ok for uhu is TTL???i put some encoer specs atached here.
2.i tested voltage everithing is ok but i dont know german and as in picture in place of 0 volt is 5 on my board{dont know what say there about measuring where to put -of multimetter?)is a problem somebody cheked that diode and iss not ok 5 volts?{ i measured all pind with - on the uhu board an + on each pin all but there i got 5}
3. can you give me some layot schems and docs for encoder receiver emitter for differential lines?if my encoder is not ok i can update him with differental lines to work in uhu?
4.some simple step dir program for testing servo???or tell me step by step how to run from uhu soft{E 2000 G 30000??ANS HE WILL RUN?}
5.btw i want to build an wood router for sculpture..hope i succed and dont regret a lot of money sped without result
6 thx . i know i will find here help ..i watched you for about 2 years nice guis..
best regards: ben
forgot another thing to asc what about with those colored pins on ic's?
and please help to do breakboard for 3 axys..image detail ..{for me a beginer in electronic and this domain an image make more thamn 100 words and her e s my controller
