Running a Quickload Servo 80 LNS Bar feeder on a 2008 Okuma Captain L370. Does anyone have a sample program for the bar feed cycle. I'm new to this servo style machine as are existing bar feeder is an air assisted pusher with the use of a bump stop on the turret. Feeder is a SMW Spacesaver 2000. This new set up uses no bump stop and has me confused...i can run through a bar i have loaded manually, but i can not get it to push a new loaded bar past the point of the top cut position. What i mean is that it loads the new bar, pushes to top cut position, but will not advance to the part length push. No alarms or errors occur and neither Okuma tech support or LNS have given me any helpful info or reasoning to why. Can someone please help me ?!?
THANK YOU.
