586,005 active members*
4,979 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Upgrading to 3D - Help me choose
    Hello,
    I have bought VCarve 4.6 and like it a lot. The main reason for this is that it is easy to use and posts files directly in to Mach 3.
    Now I want 3D, and Vectric Cut 3D is the natural choice because of the same reasons that I like VCarve. I plan to do turning within the year also.
    My question is this:
    Since I do most technical designs, and Vectric is more aimed at the sign and art segment; Is there other packages I should consider? I am in the process of adding CNC to my lathe, so what I would like to know is if it's a CAM program that will do both turning and milling, and still have the same easy interface that VCarve have? The price should be under 3000$
    Happy to hear from you!
    Jan 2008
    24
    Angry Good Luck
    Good luck with your search. Most reputable CAM software is priced WAY over $3000.00. I doubt you will find anything on today's market that will fit your requirements. Please prove me wrong. I think today's CAM sysyems are horribly over priced.
  1. Upgrading (2) D&M 5 CNC Lathes
    By basch3 in forum Mini Lathe
    Last Post: 02-12-2011, 08:24 PM
  2. Something Old, Something New..Upgrading An Old CNC Millrite
    By Too_Many_Tools in forum Knee Vertical Mills
    Last Post: 04-10-2010, 03:48 PM
  3. Upgrading from X to X3
    By tumchie in forum Mastercam
    Last Post: 01-03-2009, 10:50 PM
  4. Upgrading to TCNC 4.1
    By cbcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2007, 09:47 PM
  5. Upgrading 3 jaw chuck?
    By scbvideoboy in forum Shopmaster/Shoptask
    Last Post: 04-03-2007, 01:52 AM
