I'm just remaking my bench sized mill a bit, want to get it right this time.
I have a notion that the best way to hold a ball screw is under tension between two axial bearings. The most compact way to get that tension is with Belleville washers.
From somehere in my dim and distant past I also have a notion that 560 lbs of tension is about right, a quarter ton. Does that sound credible or am I way off the mark?
To gauge the tension I'm thinking 2 washers with different rates facing each other. One crushes flat at around 560lbf and acts as the gauge, the other is altogether stiffer and still has some way to go.
Bellevilles don't exactly appreciate being crushed flat so guess I'd have to replace the lighter one whenever I wanted to recalibrate.
