Hi there
After the firm purchased a Mori Seiki NL2500 we have been having trouble
1st sorting out our post we can not do radial tapping, I've looked through the manual but its not very helpful if someone has a sample prog. I could look at it would be very much appriciated
Also milling a hex on the end ofa shaft thats just been turned:
we first tried using mastercam but it was out of position by 7 thou in the x axis and 10 in the y any sugestions? - for this job we ended up cutting the hex and offsetting tool geometry offsets to compinsate for misalignment, before starting the inside of the collet chuck was dialed zero in X & Y axis.
the 2nd attempt was using capps to programme the hex and it also was out of alignment... ???
with the new machine its frustrating trying to prog. it and to get prog.s to run as the programming manual is very vague does anyone know of a manual that is more user friendly when refering to reqd codes?
