586,024 active members*
3,801 visitors online*
    Feb 2007
    31
    Need Help with Drawings
    I've been using emachineshop to design parts that I make on my manual mill. Now, I want to outsource the machining to a local shop. So, I need drawings with dimensions. I've been fiddling with Alibre and progeCAD, but the learning curve is too steep for me to get it done in time. Does anyone know of someone that can use my emachineshop files (.ems) as a reference to create the drawings (or files) that a CNC machine shop needs? Or, someone that can machine (CNC) the parts using my emachine files? I'm in eastern Connecticut, USA.
    Thanks in advance.
    - Don
    Sep 2008
    117
    Don
    You can export your Emachineshop drawing as a DXF which may suffice assuming your .ems file is to scale. You'll have to provide tolerances etc.
    Gene
    Feb 2007
    31
    Quote Originally Posted by easymike29 View Post
    Don
    Gene
    Gene,
    Thanks for the reply.
    I was under the impression (from reading other threads here) that the eMachineShop DXF exports weren't usable. Are you saying that they are, as long as the eMAchinShop part is created properly? If, so that is great!
    They also now export .igs files. Is that even better?
    Thanks again,
    Don
    Sep 2008
    117
    Quote Originally Posted by dleroi View Post
    .....I was under the impression (from reading other threads here) that the eMachineShop DXF exports weren't usable....
    Thanks again,
    Don
    I successfully exported the file "Blanking Complex Sample.ems" to a DXF file and opened it in both Autocad12 and Intellicad 2001(a free program). I didn't have any luck with the IGES export.
    Gene
    Update
    It seems that only the 2D information is valid in the DXF file.
    Gene
  1. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
  2. OT drawings
    By praest in forum MetalWork Discussion
    Last Post: 01-16-2008, 10:04 AM
  3. Tap To Drawings
    By bumper in forum BobCad-Cam
    Last Post: 03-24-2006, 02:43 AM
  4. CAD Drawings
    By rfmerrill in forum Uncategorised CAM Discussion
    Last Post: 05-03-2005, 12:43 AM
  5. CAD Drawings
    By noid in forum Employment Opportunity
    Last Post: 09-30-2004, 04:14 PM
