585,894 active members*
5,240 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 0-MD Machine loses absolute coord with reset
Results 1 to 7 of 7
    Sep 2008
    12
    I'm operating an EAGLE 1000 with a fanuc 0-md control.
    Every time the reset button is pressed the absolute coordinate values change losing the g54 coord reference. The only way to bring the right coords back is to reference the axis (xyz home).
    any help please
    Please check that the Manual Absolute switch is on, G127.2 is showing 1.
    Kind Regards
    Frank Moss
    Fanuc Repair
    Sep 2008
    12
    Hi Frank
    I much appreciate your reply
    Ive checked the parameters and the bit is set at 1
    G0127 00000100
    Is this right?
    Ian
    It is the diagnostic no (DGN) that you check press the param/dgn button twice to display dgn screen, then page down to g127.
    Regards
    Frank
    Sep 2008
    12
    I have the right diagnostic page g127 00000100
    ian
    Oct 2008
    106
    DGN G127 bit 2 = 1 mean Absolute is on
    Your machine doesn't have a Absolute manual switch but you can go to OPR page to turn it off
    Ahn Vuong
    Sep 2008
    12
    SUCCESS
    Thanks for the help.
    It was the switch on the OPR page set wrong. THink it was the apprentice pressing buttons again!!
    Once again thanks
    ian
  1. Absolute minimum machine spec for EMC2 latest build?
    By irving2008 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-24-2008, 12:30 PM
  2. machine reset parameter
    By priyo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-28-2007, 07:45 AM
  3. Coord rotation and multiple coord systems
    By Shizzlemah in forum Fadal
    Last Post: 10-30-2007, 09:27 AM
  4. Absolute zero of the CNC Machine.
    By Evolution VIII in forum DIY CNC Router Table Machines
    Last Post: 06-17-2007, 05:43 AM
  5. BP Series II Interact IV spindle causing machine to reset.
    By ronmarkum in forum Bridgeport / Hardinge Mills
    Last Post: 01-25-2006, 07:58 PM
