585,978 active members*
4,539 visitors online*
    Feb 2009
    123
    "Soft Stop" error MPC6515
    Hello
    once again i have got some (hopefully minor) problem with my laser engraver.
    it has been working perfectly but today refuses to preview or cut anything -instead error message is displayed on the machine " soft stop" and a series of beeps. jog, and laser pulse all work ok.
    any suggestions welcome!
    thanks
    KP
    Jan 2006
    19
    KP
    That's where you have stopped the x-y axis and tried to run a cut program that will run outside the machines parameters
    I'll asume your machine is 900x600.
    i.e if you set the x-y to say 400, 400 then download a mol to machine that has a size of 550x250 this will overlap the machine parameters by 50mm on each axis, the machine throws out a soft stop message
    hope this helps
    Rich
    Feb 2009
    123
    Rich, thanks
    thats exactly what the problem is ( thanks Frank also who has advised the reason behind the error ) - makes perfect sense now.
    So it appears that somehow i have inadvertently changed the machine to operate the cutting program relative to the head's current position. Rather than to absolute coordinates ( ie relative to 0,0 ) - as it was functioning previously.
    i assume this is a setting in Lasercut 5.1 software? - since i havent tampered with anything other than the jog distance on the machine control pad.
    any clues?
    Regards
    KP
    Jan 2006
    19
    I doubt whether you have altered any parameters.
    If you do a cut & position the laser head anywhere away from datum, once this cut is finished the machine assumes this is the datum point to start the next cut, if it's a larger cut from the previous cut it will throw out a soft stop error.
    Just try moving the laser head to allow sufficient x-y for new part & reload, should be ok from then.
    Alternatively datum the machine before each cut. i.e. push the datum button on the panel before you load a new cut file, the laser head will then move to where you have the laser start point in the software.
    Rich
  1. "Runtime error 9 - subscript out of range" on Techno CNC interface
    By zhoudfoster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2009, 04:57 AM
  2. Replies: 2
    Last Post: 06-13-2008, 11:18 AM
  3. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
  4. Mach2 bombs when I hit the "stop" button
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2005, 04:09 PM
