585,875 active members*
4,057 visitors online*
IndustryArena Forum > Community Club House > Very odd indicator readings
    Oct 2007
    307
    Ok guys, im still scratching my head with this one, and bear with me, I just got home from a 13hr shift (words may be off). We run round fixtures on the Integrex E-410 5axis at work. (lathe/mill combo). When we indicate the fixture in, it has 2 pins in-line with eachother, or has a round incating ball stud that is also inline. We have to roll the c-axis so that the centerline of the part is correct when we mill the side rails on it. The dowl pins are in the center of the part. The part is called a slip and its made in a ring, then sawed into sections and then we mill the side angled rails on it. Well, anyway. I indicated the dowl pin, teached C zero on G54. Ran one part and somehow the centerline was off. So, I put the ball stud in the fixture, and indicated the ball stud, only .007* in C off, now we put in a co-axial indicator and it showed .039* C off. How the heck can my Brown and Sharpe Best-test indicator with a Indicol Adjustal holder be that much different when indicating the same exact thing? We used a drill chuck in the spindle to hold the co-axial and I clamped on that with my test indicator. Any ideas?
    Dec 2008
    If your indicator is @ an angle (not square to the pin) the reading is false. Also try a swiss made indicator.
    Jan 2007
    355
    If the spindle isn't perfectly perpendicular to the part, and if there is a difference in the "Z" spindle position (using different indicators) when tramming the pin, that could account for the difference.
    Try setting an angle plate on the fixture locating surface, then tram the face of the plate to check for an "out of square" condition.
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Oct 2007
    307
    Quote Originally Posted by odind View Post
    Brown and Sharpe is swiss made.
  1. Dial indicator -advice?
    By Kalvin in forum Benchtop Machines
    Last Post: 04-04-2013, 01:09 PM
  2. Different resistance readings in an eight wire stepper windings
    By miro in forum Stepper Motors / Drives
    Last Post: 12-16-2008, 03:44 PM
  3. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
  4. what does dial indicator use to measure?
    By cnc2k in forum MetalWork Discussion
    Last Post: 07-16-2005, 01:20 PM
  5. Fuzzy Oscilloscope readings.
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 03-27-2005, 12:49 AM
