Hello all!
We have a 1992 Fadal 3016 w/88 control that has spindle orient issues.
We went into the parameters and adjusted the spindle orient variable up and down by small increments as per the manual, but we still have inconsistent spindle orientation.
What we see is it will orient OK most of the time (although slowly compared to the 2001 and 2006 machines we have.), but occasionally it will either not turn the spindle enough to lock in, or it will over-run the detent and eventually fault.
The air pressure on the machine is a consistent 90-100 psi.
My question is, are there any other adjustments or wear items I need to look at or is this just a sign of age on the machine?
Any help would be greatly appreciated.
Thanks in advance!
James Winn
