585,760 active members*
4,019 visitors online*
Results 1 to 14 of 14
    Jan 2004
    111
    Open source Eagle pcb files
    Has anyone made eagle files of the open source stepper drivers. Just curious.
    Jun 2003
    3312
    Are you referring to these?
    http://webpages.charter.net/pminmo/cncelectronics.htm
    If so they were all developed in Eagle Free version.
    Phil
    Jan 2004
    111
    Yeah those are the designs but what i was wundering can the eagle drawings be posted as well. I'm just getting my second pcb mill built. First one was less then usuable but it was a good start. This next one should be able to router pcb's. I am just learning to use eagle, its a great program. I have several issues in that the driver board i have is based on the cw tech ucn5804b board. What i would like to do is mill the pcb's for some of your better designs. Then upgrade the driver boards.
    Or do you think it is worth my time to try and work the schematics out and then get boards from eagle on my own? Or would that be more then something a beginner can do?
    I'm pretty much just starting to learn to use all this stuff. I have done the toner transfer method before, but i would like to have the mill do the work. In the end i would like to learn and use pic microcontrollers and this seems like a good place to start.
    What boards do you recommend? I noticed that the 3977 is an internally chopped board. As well as the l297/8 boards. Or would tachus42 design be better?
    Any info is greatly appreciated.
    Jun 2003
    3312
    I originally had the eagle files on the website but ran out of room. A zip file containing the eagle schematic and board files for the 5804 is attached. Each board has it's merits. The 5804 is the simplest with half stepping and that is it's stong point, the discrete will drive the most current and is simple. If you want one of the other boards just post and I'll attach em. The only exception is the 3977 board, I'm a little more judicious with that one because of the level of difficulty. Before your start down the pic route, look at AVR's by Atmel. www.atmel.com Very popular, cheap, easy to get, some free tools including a free basic complier for less than 2K of code, easy to program. Do a google search on avr and you'll see there is a ton of info out there on them. The go as small as an 8 pin package to very BIG. On board 10bit adc's on many of them, all esquared and flash memory.
    Phil
    Attached Files Attached Files
    Jan 2004
    111
    Thanx for the file. I have more then a dozen pic's from their free samples. That and i have a book for them. I am interested in avr's as well, i'll have to do some more looking around. But besides that i still wont to be able to mill my own pcb's. I just finished my new mill today. Now i have to connect the bigger motors and then start figuring out were i'm going to put my limit and home switches. Thanx again Phil.
    Jun 2003
    3312
    Attached is the eagle files for Tachus42's 3 axis discrete board and 3 axis chopper.
    Jun 2003
    3312
    Attached is the eagle files for the 4 axis interface board:
    Jun 2003
    3312
    Eagle files and word document on the single axis discrete driver.
    Jun 2003
    3312
    singe channel L297-l298 eagle files:
    Jan 2004
    111
    Thanx for the christmas presents Phil. Have a merry christmas and a great new year.
    Aug 2004
    170
    WOW, That´s called OPEN SOURCE !!!!! Wonderworld !!!!!
    Long life to PHILL and CNCZONE !
    Jul 2005
    42
    I've hit the open source driver goldmine!!!! Thanks for sharing. The world is a better place now.
    Apr 2005
    16
    have anyb, servo driver 3 axis board shematic/eagle file too ?
    and stepper board what can use high current motors 4,5-6A
    i have meny 4-6A stepper but not found good 3-4 axis driver board into web.
    now i use only low power 2A motors to board is 3d-step max 2,5A current(no good,need more current and biggest motor)torgue is better if use big motor.
    Oct 2004
    Could you post the eagle files for the opto isolated breakout board? Didn't see them anywhere.
    Keith
  1. PIC Open source Servo Driver Schematics development?
    By Rossz in forum Open Source Controller Boards
    Last Post: 10-26-2011, 09:37 PM
  2. Any ideas for open source CAM package?
    By galacticroot in forum OpenSource Software
    Last Post: 10-22-2007, 05:35 PM
  3. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  4. What's in work at the open source
    By pminmo in forum Open Source Controller Boards
    Last Post: 02-13-2005, 08:55 PM
  5. Open source driver designs
    By pminmo in forum CNC Machine Related Electronics
    Last Post: 05-05-2004, 03:29 PM
