585,930 active members*
3,303 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Pocket island depth
Results 1 to 2 of 2
    Mar 2009
    3
    Pocket island depth
    I'm trying to make a pocket with multiple depths in it. I've figured out that if I select islands and choose "use island depths' in the depth cuts dialog, I can get it to cut over islands.
    So far so good.
    What I've found now, though, is that those cuts will at whatever the nearest depth cut step was. So, if I have an island 0.15 in below the surface and I'm cutting in 0.1 in steps, it will only cut down 0.1 in, and leave behind that extra 0.05 in.
    Is there any way to make it automatically go back and machine that last little bit?
    Paul,
    I'm not sure which version you are using. but this will work as far back as V8 I think. On pocket parameters page select island face, there will be a button at the bottom you can adjust the stock left on top of the island. You should draw the island in the pocket at the z depth it will be cut at , this will work best for you.
    Steve Arteman
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
  1. 2007 pocket/island
    By marty7001 in forum BobCad-Cam
    Last Post: 07-19-2007, 08:59 PM
  2. Pocket With Island (Solidworks parts)
    By Benji in forum EdgeCam
    Last Post: 12-31-2006, 03:16 PM
  3. Pocket with Island - Edgecam V10
    By Mike Mattera in forum EdgeCam
    Last Post: 11-01-2006, 11:10 PM
  4. Multi Depth pocket
    By camtd in forum EdgeCam
    Last Post: 09-06-2006, 01:24 AM
  5. Depth of Pocket for Letters
    By whiteriver in forum Composites, Exotic Metals etc
    Last Post: 10-15-2004, 08:24 PM
