Is anyone using a bluetooth to rs-232 adapterto send files and dnc files to their haas? If so is there any certain type that I should look into? And is there any problems that you have had with the setup?
I use the ConnectBlue SPA312i bluetooth to RS232 controller - it is designed for industrial use and it works great. I attached it to my mill, and plugged it into the switched 115v power outlet, so it turns on when i turn on the mill. The antenna is on top. Now I have a 3500lb mobile bluetooth device
http://www.connectblue.com/products/...sings/spa312i/
They are pretty pricey new, but i bought mine on eBay for $100.
Absolutely no problems. configured for 115k communications.
