584,837 active members*
5,384 visitors online*
    Mar 2008
    114
    Heidenhain 4th axis
    Hello - I am looking for somebody who has a Heidenhain TNC 155Q control with a working 4th axis who is willing to tell me the Heidenhain part# of the encoder that it uses. I am building a 16" CNC rotary table for my machine and need to find the correct encoder that will connect to the controller. Even better yet would be finding someone who wants to sell such an encoder....
    1121
    re
    any heidenhain encoder of the appropriate vintage ought to work. There are parameters for type and line count etc. Doesn't have to be heid., but they will plug in
    Nov 2008
    69
    Encoder input
    on the Heidenhain TNC155 has only to possibilities.
    If the rotary encoder is fitted to the center of the table the line count must be either 18000 or 36000.
    Those encoders are very expensive. If you fit the encoder to the motor then you need to calculate the ratio of the motor/table and come up with the same line number / table turn.
    The signal of the encoder must be 11uApp (16uApp in the older version do well)
    Jukka
  1. Hermle / Heidenhain 5-axis accuracy
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 03-17-2009, 07:47 PM
  2. Bridgeport s II interact II z-axis HEIDENHAIN
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2008, 01:15 AM
  3. Heidenhain 155Q Problem with x and Y axis
    By Zoni in forum DNC Problems and Solutions
    Last Post: 04-05-2008, 10:33 AM
  4. Five Axis Heidenhain Post
    By TonyCarter0001 in forum EdgeCam
    Last Post: 03-25-2008, 10:28 AM
  5. Heidenhain 2500 - Programming Z Axis
    By palikalsi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2007, 02:46 PM
