Doesn't the back have to be left open to allow somewhere to place the object to form the relief?
One problem you'd have is the substantial weight of the whole thing: 800 pounds or so. 1" pin length may not give you all that much travel to form a significant relief, since the pins must be nested for some length. Depending on what you wanted to do, maybe a 2" long pin would be more practical.
Perhaps headless pins would be better, a spiral roll pin would be a tiny bit less heavy. Just let them nest against one another. Perhaps if you magnetized the whole lot of them (roll pins are hardened and probably will acquire and hold some residual magnetism), they would kind of stick together well enough to stay put (or maybe not). Perhaps placing a real magetic "booster rod" every so often would accomplish the same thing.
You might want to fashion some kind of a vise type frame for it, so you could tighten the whole thing up to lock in a shape in the relief.
