Hi all,
after have successfully used the proxxon bfx40 setup for a while, I have understood that ( to speed-up jobs ) I need a bigger setup.
Actually I have seen a couple of machines that seems to be right, but I need your advices on which would be better, just to avoid a bad choice.
The two products are :
http://www.hbm-maschinen.de/output/c...r.aspx?cid=166
and
http://www.harborfreight.com/cpi/cta...emnumber=44991
( but the european version, that is metric units ).
For the first one there is no Z microfeeder, but on the main site there is a project for adding such feature, and is priceless. The motor power is 500W
For the 2nd one , there is the microfeeder, but it cost almost two time then the first one, and the motor is 350W.
Anyone has never tried the first one ( I know a lot of you has the second ) and have comments ?
What do you think will be the best choice ?
T.I.A.
Pigi
