I'll just post this here to document a simple post modification that I worked up to make a working post for my Kitamura Mycenter 1 vertical machining center with Yasnac i80M controls...
Mastercam's "Generic Fanuc 3X Mill.PST" was almost perfect to run the machine. However with the generic post, my machine wouldn't do a tool change. I don't remember if it just sat there and did nothing, or if it had an alarm. Anyhow, the Kitamura requires that the Z axis is at home (zero) prior to a tool change. I'm guessing that some other machines automatically zero the z axis whenever a tool change is called.
So, a simple modification is needed to the generic post to make it work for the Kitamura / Yasnac. The post needs to tell the Z axis to go to zero prior to each tool change.
Here's how to do it:
Make a copy of the Generic Fanuc 3X Mill.PST and rename it for your machine. The file is located in [installation directory]\mill\posts.
Scroll down to the label "# Start of File and Toolchange Setup"
After the block that says:
if mi1$ <= one, #Work coordinate system
absinc$ = one
pfbld, n$, sgabsinc, *sg28ref, "Z0.", e$
pfbld, n$, *sg28ref, "X0.", "Y0.", e$
pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
absinc$ = sav_absinc
Add a new line that says:
n$, *sg28ref, "Z0.", e$ #Added by [insert your name here] to make toolchange work on Kitamura.
You should also add some comments to the header of the file describing the changes that you made. You can put comments anywhere - just start them with a '#'.
Thank god for those late nights learning programming as a computer science major back in college. I think I would have been totally lost otherwise, as the Mastercam post processor system is pretty complex.
Hope this helps and good luck!
