585,761 active members*
4,065 visitors online*
Thread: AT-300
Results 1 to 6 of 6
    Mar 2009
    Question AT-300
    Hi ya'll
    I am new here.
    I have an AT-300, its an older machine. I am interested in converting it over to cnc, to help run simpler parts at work. The work the machine is doing right now is mostly threading and turning wooden taper plugs. I have heard a few things about ELS and that may work. Where can i find info or parts to complete this project.
    Although it would be cool if it could make more complex parts.
    Tyler
    Dec 2008
    12
    AT300 CNC
    I have a AT300 that I have converted to cnc.
    send me your email address and I will send you some photos.
    Cheers,
    Glenn
    Dec 2008
    12
    AT-300 CNC CONVERSION
    Here are some pictures of my AT300 CNC conversion.
    I Used 3x 282oz in steppers which seem powerfull enough however I think 2:1 ratio is the the best for all gears.
    This mill has 2 weak points.
    1. The brass Y-Axis nut on the treaded shaft is prone to wear.
    2. Back lash on the Y-Axis shaft bearing.
    Future plans will be to improve this some how.
    The Modifications I made didn't damage/alter the Lathe so I can remove the motors later if I decide to sell it.
    Attached Thumbnails Attached Thumbnails X-Axis_a.JPG   X-Axis_b.JPG   Y-Axis.JPG   Z-Axis_front1.JPG
    Jun 2006
    Thanks for the pictures, nice work.
    Jan 2021
    Re: AT-300
    tt-boy, old thread but do you have any updates? Locking into doing something similar with my machine :-)
    Dec 2008
    12
    Re: AT-300
    Tony,
    I had several attempts at trying to convert this machine to CNC but it was never very accurate.
    The limitation I had was the Y-Axis had to much backlash in the bearing and the Z-Axis was difficult to drive through the rack and pinion gear.
    Later I replaced the X & Y-Axis with a lead screw but eventually converted the lathe back to manual control and move the electrioncs over to a CNC router I have amost finished.
    Maybe all the issue I had was because my machine was second hand when to got it and it was all a bit worn out.
    Attachment 456752Attachment 456754
