585,933 active members*
4,024 visitors online*
    Jul 2006
    122
    Cutting 5052 Aluminum
    Hey folks been awhile since I posted but need some input. When I started the original Dynatorch thread it was awesome!! We exchanged alot of ideas and information on SPV, feed rates, tips, IPM etc. All the settings I have for steel are spot on. So, now I need to cut some parts out of 5052 Alum.
    Anyone cut that before? If so I would appreciate some input on the settings so I dont waste sheet and tips.
    Dynatorch 5x10
    Powermax 1000 cutter
    Great to see so many users chiming in on projects and that all the DT owners are enjoying their machines.
    Thanks!!!
    Ed-Ryno
    www.rynomobility.com
    Oct 2005
    378
    Ed, I have cut alot of .080 & .125 5052 aluminum with my dynatorch. What thickness are you interested in cutting? Cutting larger shapes works great however warpage can be a problem if you are doing alot of cuts in a small area on the material. I recently did a pattern on a 24" x 24" sheet of 3/16. It was basicly the shape of an (H) 13" high, 7" wide with a circular center (for mounting a fan). After cutting the center circle 1st I started on the perimeter and the thermal expansion caused the material to move an 1/8" during the cut which made the legs of the (H) difference widths. When possible you can pause the torch between cuts to allow for cooling. A spray water bottle helps also. I use a Hypertherm 1250 and fine cut tips. I will have to retreive the settings for you later when I go to the shop. I usually only do 1 part at a time when I cut aluminum and the part I cut is worth several hundred dollars when I place it on the table so there is no room for mistakes.
    Jul 2006
    122
    Hey Joe,
    Thanks for the reply. I am cutting 3/16 thick sheet. Its for a wheelchair ramp and has 1/2 wide, rounded end slots, 5" long. The total size is 34 x 35, and there are 12 of the slots in each piece. The slots provide traction for a wheelchair when entering the vehicle.
    I messed around with some Aluminum after I got the machine running, but was using a 60amp tip and didnt spend too much time dialing it in. Id like to be able to do the 5052 so I dont have to pay for waterjet cutting. I appreciate the help!!
    Have a great day
    Edward Pic
    Ed-Ryno
  1. Stamping/pressing/punching holes in 5052
    By Sonicmook56 in forum Diemaking / Diecutting
    Last Post: 12-13-2008, 03:39 AM
  2. Burr Free drilling in 5052 aluminum
    By Texiwi in forum MetalWork Discussion
    Last Post: 06-11-2008, 10:07 PM
  3. 3/16 Aluminum cutting
    By zeoncomp in forum MetalWork Discussion
    Last Post: 03-14-2008, 05:54 PM
  4. Is 5052 alloy suitable for a billet wheel rim?
    By ziggyjj in forum MetalWork Discussion
    Last Post: 11-30-2005, 04:46 AM
  5. Aluminum Cutting
    By Tazzer in forum DIY CNC Router Table Machines
    Last Post: 07-29-2003, 06:09 AM
