585,599 active members*
3,495 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > HELP! Name this electronic wire connector please!
Results 1 to 9 of 9
    Jan 2008
    19
    I purchased these military style twist plugs. I am wondering what I should use to fasten the actual wires to this hardware? OR.... On the ends there is a semi circle thing. Are these supposed to be crimped to the wire leads?
    Feb 2007
    4553
    Post
    Delanoman,
    They are solder termination type MIL-C-5015 connectors.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2008
    19
    Cool thank you.
    Feb 2009
    Those are "solder cup" terminals
    You touch the sides of the cups with a 20 to 30 watt soldering iron and slightly under fill them with solder.
    You strip about 1/8" of insulation off the wires. Twist the exposed wire by hand to tighten it up, then "tin" the wire end with solder.
    Then simply heat the solder cup again and insert the wire while the solder is liquid, and hold everything still for a moment while the solder cools.
    That's it!
    May 2007
    Then try it at arms length, in the dark and rain, hanging upside down by your feet into the bowls of a millitary jet! They are loads of fun then! :-) You should be fine on the bench.
    Dec 2007
    8
    Solder Cups
    If you have any further questions you can look at my companies web site...tech service will answer any connector question you have and even provide you with free samples. Good Luck
    http://www.mill-max.com/
    24220
    I always slip a stubby piece of heatshrink over the wire, then slip it down over the soldered pin, it makes for a neat job when finished.
    Al.
    Albert E.
    Feb 2009
    16
    Almost right...
    Quote Originally Posted by Roofletch View Post
    You left out the fun part of doing all the above on the flight deck of an aircraft carrier in the middle of the North Atlantic in mid-winter storms.
    Dec 2004
    1865
    I've got a better one!!!
    (chair)(chair)Try doing it on the bench on a Saturday morning when you are actually supposed to be doing yard work and your wife is calling.(chair)(chair)
    No husbands were actually hurt in the making of this joke.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  2. 10 pin connector help
    By Rees Guitars in forum Controller Cards
    Last Post: 01-20-2008, 07:29 AM
  3. Wire&Connector Checklist
    By walter in forum CNC Machine Related Electronics
    Last Post: 12-23-2007, 05:02 AM
  4. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  5. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
