585,951 active members*
3,912 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Does Anyone Make Hobby Precision Worm Gears?
    Nov 2006
    32
    Does anyone on CNC Zone happen to make precision Worm Gears in 4" and 6" sizes for standard off the shelf worms or can also make the matching worms. Materials of interest are bronze or aluminum with 180 or 360 teeth.
    I am interested in purchasing 1 or 2 pieces for testing.
    4826
    Edward R Byers Co in Barstow, Ca makes worm gears for telescope drives. These would be fairly fine pitch in high tooth numbers intended for one revolution per day but if you can contact them, they may make anything custom.
    Nov 2006
    32
    Yes I am aware of Byers however they are priced well out my budget for what I want to do. I am hoping to find someone that has precision equipment to make these in their small shop versus going with a large company.
    Nov 2008
    small worm gears
    Try Stock Drive Products at 516-328-3300
    web www.sdp-si.com
    Jan 2008
    24
    You might check out "Small Parts Inc."
    Hammer
  1. best lubricant for worm gears
    By cameraman32 in forum Uncategorised MetalWorking Machines
    Last Post: 08-23-2008, 02:27 AM
  2. WORM GEARS - Challenging but confusing!
    By widgitmaster in forum Mechanical Calculations/Engineering Design
    Last Post: 09-19-2006, 11:19 AM
  3. Eliminating backlash with worm gears
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 01-27-2006, 03:17 PM
  4. Links to worm gears for 4th axis
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 12-23-2004, 12:30 PM
  5. worm gears, 4th axis
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 10-18-2004, 05:53 PM
