i don't know what i am doing i can't find it either now. do i have to make an account to post there?
If you are not having fun, you are not doing it right.
no, just look for the link after and copy it
John
After you press "submit post"
you get a link like this one http://pastebin.ca/1373060
John
This was on irc
SWPadnos- the if condition sets _yPos to _ySize
SWPadnos- but the while loop will repeat as long as _yPos is less than *or equal* to _ySize
SWPadnos- so it loops forever
SWPadnos- the while should be changed to LT instead of LE
ok i see that now sam. if i use lt the program dosen't do what i want it to. i found a way to get the job done. just not too happy with it.
i looked at that silly thing for several hours and didn't catch the trap.
thanks
http://www.pastebin.ca/1373248
here is the first cut of the surfacing code that actually seems to work.
set the parameters in the top of the program. zero the z axis to the top of the fixture/(bottom of the stock). run the z axis to the high place in the stock. then position the x y to the south west corner of the area to surface.
no bells no whistles but a place to work from. play with it and let me know what you think.
