585,662 active members*
3,066 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > MB1 - Overshooting Y home position
Results 1 to 3 of 3
    Mar 2009
    9
    Angry MB1 - Overshooting Y home position
    I am all of a sudden having problems with MB1 overshooting Y zero. Does anyone know how to fix this?
    X and Z home out just fine but when the Y moves home it moves past it and triggers an emergency stop.
    Just a guess but I think the limit switch is shot.
    Does anyone know how to replace one of these?
    Jun 2008
    1103
    Yep. Take off the sheet panel under the rear cabinet. In the space inside, the switches are on the right hand side and are actuated by the rod attatched to the back of the saddle. Check the switch is within 1mm of the actuator when it is at full stroke. If it is, then it's probably shot. You'll need a Honeywell 101xk5 or equivalent to swap it with. When you've changed / reset it, table zero the machine and aim to have -1.1" from zero to switch actuation when jogged -ve. Adjust as necessary.
    Mar 2009
    9
    Thanks Bloke, I will give this a try.
    You wouldnt happen to have some photos of this you could post do you?
  1. Fanuc 18 TT home position
    By Mekcanix in forum Fanuc
    Last Post: 12-10-2008, 09:44 PM
  2. Home Position
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 03-26-2008, 04:30 PM
  3. Plasma Home Position
    By Big John T in forum Waterjet General Topics
    Last Post: 03-24-2008, 02:24 PM
  4. Home Position Fanuc OM-C
    By Derek.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-28-2007, 08:06 PM
  5. Home switch position
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-17-2004, 01:00 AM
