585,728 active members*
4,383 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Modelling & linetypes
Results 1 to 13 of 13
    Jul 2008
    81
    Hi guys,
    further to me recent post(s) I would like to know about linetypes when modelling. I have done very little modelling and understand that a 2D drawing can be created from the 3D model. I just wondered what needs to be done to show different linetypes in the 2D drawing such as a hidden profile when taken from the 3D model.
    I have only ever done a 2D drawing or a separate 3D model and not one from the other.
    Thanks!
    Is this AutoCAD?
    Jul 2008
    81
    Sorry, yes it is Acad 2008!
    I have done some further research using some old R14 books I have and they mention using PROFILE command. Is this still the case? If so I'll give it a go soon.
    Look in the help file for SOLVIEW and SOLDRAW commands. I believe that they will automatically do the hidden lines. I've only played around with these once or twice, though, as I prefer to draw the 2D myself.
    Jul 2008
    81
    Thanks Gerry,
    I believe those are the commands that I read about.
    One other thing, can you advise the best way to draw a threaded hole on a 3D model so the 2D drawing shows the core diameter as well as the thread diameter?
    I'd just add it to the 2D drawing.
    Jul 2008
    81
    Exactly what I was thinking!
    Mar 2007
    37
    been a while since i've done this, but i think SOLPROF and FLATSHOT will help, don't forget SECTION also
    FLATSHOT creates a flattened view of all the 3D solids and regions in the current view. The resulting view is a block that is a flattened representation of the 3D model
    I'd never heard of Flatshot, but it's pretty sweet.
    Jul 2008
    81
    Ok guys I'll give that a go when I get a chance.
    What is the correct 3D convention when modeling internal or external threads in AutoCAD?
    For an internal I would guess the core diameter. For external obviously the OD but how would the core or thread length be represented on the model?
    Mar 2007
    37
    Typically the hole is modeled at the ID for parametric modelers that have a hole tool. See attached video for how this is done in Inventor.
    Also, note that AutoCAD Mechanical has a hole tool as well, Here's a quick video showing it also.
    Hope this helps.
    Attached Files Attached Files
    if you can email me an iges or parasolid of your drawing I can send you back a 3 view ortho you can work with for your toolpaths..
    [email protected]
    Jul 2008
    81
    Ok I think it's gone beyond what I was asking. Don't forget I'm modelling in Acad 2008.
    jrlifter, how will the toolpaths help?
  1. PRS modelling
    By betterfly in forum Musical Instrument Design and Construction
    Last Post: 08-13-2008, 10:00 PM
  2. 3D modelling in the real world
    By ksealey in forum WoodWorking Topics
    Last Post: 11-30-2007, 08:06 AM
  3. Modelling a Guitar for a Variax transplant
    By nshack31 in forum Autodesk
    Last Post: 03-17-2006, 04:24 AM
  4. Learning 3D modelling
    By randyf1965 in forum Uncategorised CAD Discussion
    Last Post: 01-12-2006, 01:27 PM
  5. guitar neck modelling....
    By anoel in forum Rhino 3D
    Last Post: 04-17-2004, 05:33 AM
