585,886 active members*
6,247 visitors online*
Results 1 to 8 of 8
    Apr 2005
    108
    MV-40 tool falling during work
    In my machine after I change the tool start working some time the tool is falling from the spindle I checked the grriper and by marking I found that the gripper hold the pulstud only for about 0.5mm I checked everything took a part the springs and the gripper but not finding nothing that will not hold the tool like suddenly I need to change for bigger pulstud
    did some one of you got this kind of problem
    Mar 2008
    31
    most probably, the drawbar cup springs are broken.
    Apr 2005
    108
    sorry but this is not the case
    the gripper not closing all the way on the pullstud
    Sep 2008
    33
    dango,
    Are you saying that the difference in drawbar height (when clamped) only changes .5mm when there is no tool in the spindle? The spindle drawing in the parts list should show the amount of stroke (or distance to the top of the drawnut) your drawbar should have. If the drawnut is too tight, its stroke will be too small to allow proper clamping pressure. In this case, back the nut out until you achieve the stroke listed in the parts list
    Does the problem occur with only one tool or many different tools? How quickly does the tool fall out of the spindle after the tool change?
    Did you count the belleville washers and make sure they're arranged properly?
    Usually, they're stacked in pairs. If one pair is flipped around, it will reduce the stroke. They're usually stacked like this;
    Dec 2008
    3109
    I agree
    Any problems with the curved washers affects the ability to hold the pull stud and tool firmly in the spindle taper
    Your service person should have a special tool to mount in the spindle to measure the draw-bar pressure on the pull-stud , and / or set it to the correct pressure.
    Apr 2005
    108
    I think you did not understand me
    I will try to explain it again
    The gripper holds the tool on the pull stud by 4 fingers
    The pull stud have head and then became a neck the fingers when they grub
    The tool and going all the way up at this time the fingers close and holding
    The pull stud and they touching or almost touching the neck of the pull stud
    In my machine they are not closing enough but only 0.5mm over the head
    So because of that when you cut it fall
    I checked the spring and all the parts of the drawbar but
    Could not find what cause the problem
    It like the pull stud became suddenly too small and I need to increase the size
    Of it
    Mar 2008
    31
    please refer to attached retention knob table. May be of help to resolve this fault
    Attached Files Attached Files
    4826
    What about wear of the fingers? Is that possible? Are you using the exact pullstud recommended for your machine? No oddballs in the mix?
    Can you measure the travel of the drawbar somehow? Compare the travel distance with no tool compared to the travel with a pullstud in the gripper.
  1. Winchester 1885 Falling Block Rifle Blueprints
    By Nono in forum Hobby Discussion
    Last Post: 11-20-2013, 08:47 PM
  2. CNC lathe tool and work offsets
    By mm4039 in forum MetalWork Discussion
    Last Post: 11-18-2013, 06:28 PM
  3. It Keeps Falling Apart
    By Bluesman in forum Environmental / Alternate Energy
    Last Post: 03-11-2008, 05:29 AM
  4. Chuck Falling Off???
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-25-2008, 08:33 PM
  5. Best way to set work/tool offsets?
    By TechCenterTeach in forum Haas Mills
    Last Post: 12-29-2007, 06:27 PM
