585,602 active members*
3,659 visitors online*
Thread: Yasnac help
Results 1 to 13 of 13
    Jan 2004
    258
    Yasnac help
    I have a shop here in the area that has a kia with a Yasnac controller on it. It been 14 years last time I ran a yasnac, I need some help?
    Jan 2006
    4396
    Quote Originally Posted by cncwhiz View Post
    What kind of help are you looking for??? Programming, Set-Up????
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jan 2004
    258
    Setup and controller operation.
    Jan 2006
    4396
    Can you be a little more specific like what Yasnac Control MX1, 2, or 3???
    What Configuration VMC or HMC?
    What Year??
    Toby D.
    Schwarzwald
    Jan 2004
    258
    Im trying to find out. I know that the control is on a KIA but that it?
    Jan 2006
    4396
    Look for the Manuals. They will have the Control information as far as what Model, Year, and Configs.
    If you find manuals that are crappy match them up on this site. There are complete PDF's (bad photo copies but good enough).
    Then post back here.
    http://www.yaskawa.com/site/Support....ntrollers.html
    Toby D.
    Schwarzwald
    Jan 2004
    258
    The machine is a lathe. I am not sure of the controller but the guy is supposed to get in touch with me. They are having programming issues. They are doing trial and error?
    Jan 2006
    4396
    Problems with what? Canned Cycles?? Set-up??
    It is more than likely an LX 1, 2 or 3 series Control.
    You may have to set the stroke limit with a G50. This is done by setting all the tool geometry in the Offset Page then Set the Stroke Limit for Tool clearance for Indexing each tool change. I forget the exact sequence.
    I have not done this in like 10 years myself LOL
    Toby D.
    Schwarzwald
    Jan 2004
    258
    Im waiting to see if I can hookup with the guy. Im a Pro manufacturing programmer? I have mastercam but I don't know much about it? I have a friend that programs lathes in his shop that can get me going when I find out what the guy with the machine needs?
    Mar 2006
    56
    Yasnac on KIA
    If you have any programming wxperience with a Fanuc, the Yasnac is very similar with a few minor changes.
    You need to supply a lot more information before I can help you. For instance does it have a tool presetter?
    What model is it?
    Is it a gang style machine?
    What are you going to run on it?
    How old is it?
    I used to work for KIA so I am sure I can help you.
    I also may have some manuals.
    Jan 2006
    4396
    Quote Originally Posted by lyfordln View Post
    What model is it?
    How old is it?
    Pretty much a standard Lathe. No live tooling, No Pre-Setter
    Toby D.
    Schwarzwald
    Jan 2004
    258
    Yes they are telling me that it is a gang tooled lathe. I don't know what they run but the don't seem like they know much about programming?
    Jan 2006
    4396
    I will have to correct the above statement now LOL. Is this one of those little 5C collet machines with a Gang Slide?
    Toby D.
    Schwarzwald
  1. how to dnc a yasnac mx1
    By matosjulio in forum G-Code Programing
    Last Post: 02-06-2009, 10:26 PM
  2. Yasnac LX3
    By inthedark in forum MetalWork Discussion
    Last Post: 08-07-2008, 11:03 AM
  3. Help on Yasnac 2000G
    By ktb100 in forum DNC Problems and Solutions
    Last Post: 07-05-2008, 03:31 PM
  4. yasnac J 100 M
    By Furlan in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 11-17-2007, 04:55 PM
  5. Yasnac I80
    By Gitanes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2005, 06:00 AM
