585,712 active members*
4,237 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Romi Bridgeport EZPATH-S DX 32 thread cycle problem
Results 1 to 7 of 7
    Dec 2008
    4
    Hi, my name is Peder and this is my first posting on this forum. I must say I find the forum very useful.
    I am the proud owner of a 1997 Romi Bridgeport EZPATH-S with a DX 32 control.
    I have a problem with the thread cycle, not the initial cycle which performs ok, but repeating the thread cycle is a problem.
    When I repeat the cycle it misses the threads.
    Have anyone come across this problem and have found a solution as to how I can solve it?
    Thank you very much in advance for your help.
    BR//Peder (Norway)
    Feb 2005
    154
    "It misses the threads"
    Hello Peder,
    When you say you are repeating the cycle. What are you referring to? Is this the next part? Or are you repeating the cycle to cut the threads deeper? What exactly do you mean by misses the threads. I have the same machine.
    Dec 2008
    4
    Hi,it is when i repeat the cycle to cut the threads deeper! Have also discoverd that the spindle speed is 10-15% of. When i set the speed to
    500Rpm, the control say 500Rpm. But when i measure it, it is actually 512Rpm,and stable.
    Missing the threads: It dont hit the threads dead on,it hits the threads half a thread of. Havent don threads for some time,4months or so.And everything workt ok before.
    Best Regards.
    Peder
    Thanks for your Reply!
    Apr 2009
    hiya peder.although, im new both to CNC,ing & this site i mayebe able to help.are you using a G76 multiple thread cutting cycle? & are you remembering to cancell your G96 constant speed surface.the problem could also be with your cutting speed being too low,although i dont know what material your machining,& the number of passes your using,also check your feedrate isnt too high or two low.you can check the pitch you require & set the feed rate accordingly
    Nov 2004
    3028
    Are you starting from the same Z point?
    George
    Dec 2008
    4
    Hi George, yes the start point is the same!
    Peder
    Dec 2008
    4
    Red face
    Hi, I still struggle with my thread cycle/ spindle problem! Can anyone tell me how to go to/get in to Dos on a DX32 control? So that I can adjust the spindle parameter!
    Peder
  1. Bridgeport/Romi EZPATH Schematics
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2011, 12:00 AM
  2. Bridgeport EZpath lathe
    By camtd in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2009, 09:55 PM
  3. EZPath II CSS problem
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2008, 07:43 PM
  4. Bridgeport EZpath Axis fault
    By klxrcr in forum Bridgeport / Hardinge Mills
    Last Post: 10-01-2008, 02:48 AM
  5. Bridgeport EZPath help needed!
    By VSMIGuy in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2007, 12:58 AM
