585,932 active members*
3,809 visitors online*
Thread: thread pitch
    Jun 2006
    217
    thread pitch
    What would stronger in aluminum.....1/4 x 20 tpi or 1/4 x 28 tpi ?
    Nick http://www.nixstuff.com
    http://www.youtube.com/watch?v=jTu7wicVCmQ
    Jul 2005
    12177
    You might find disagreement of opinion on this one.
    I have done tear out tests on 6061 and found that 1/4"-20 is better than 1/4"-28 by quite a bit.
    This was with cutting taps not form taps and I have no idea whether the results would be different for form taps.
    I also found that if you have a correctly tapped 1/4"-20 thread using a 13/64" tap drill, which gives about 75% thread, 8 threads engaged means that the bolt is almost certain to break rather than the aluminum strip out with a socket head cap screw that is equivalent to Grade 8. Using Grade 5 bolts 6 threads engaged is enough that the bolt will probably fail first.
    There is a caution however: If you constantly tighten, loosen and retighten threads in aluminum it will fatigue the thread and this will result in failure in the aluminum.
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
  3. Replies: 24
    Last Post: 11-18-2008, 03:37 AM
  4. help cutting 6 pitch thread
    By joe1970 in forum MetalWork Discussion
    Last Post: 06-09-2006, 02:43 AM
  5. New Ballscrew Pitch?
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 12-06-2004, 04:02 PM
