585,662 active members*
3,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Enclosure for a Enshu AccuMill
    Mar 2009
    15
    Hello,
    We have an Enshu AccuMill AM-1475 Vertical Knee Vertical Mill and we would like to fabricate an enclosure to keep all the chips and cooling fluids contained.
    Wondering if anyone has already done this or has an idea for something simple that would be as affective as a full enclosure but not as time consuming or costly.
    We mill Stainless Steel only and the chips get stuck every where and quite painful when you get the little splinters all over the place.
    Adam
    Aug 2020
    14
    Re: Enclosure for a Enshu AccuMill
    I have problem with same system, a “not ready” alarm that won’t go away. Details here, pls help.
    https://www.cnczone.com/forums/fanuc...tem-ready.html
  1. NEED ADVICE re: Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By crobox in forum Knee Vertical Mills
    Last Post: 01-20-2023, 10:00 PM
  2. Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By fixer2 in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:37 PM
  3. HELP Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By EDL at AU in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:31 PM
  4. Enshu ! VMC 330
    By Camfather in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2020, 11:56 AM
  5. NEED HELP - AccuMill AM1547 + BobCAD + Predator
    By AccuMillGuy in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2009, 07:25 PM
