585,981 active members*
4,478 visitors online*
Results 1 to 8 of 8
    Feb 2009
    5
    Tool Drum On Arrow 750
    Hi
    Has anybody had trouble with the motor on the tool drum.
    Mine dose not index to the next tool. The air blast works but the drum dose not turn. I taped the motor with a rubber hammer and it started working.
    It worked for 2 days then stoped again. I think the motor has a dead spot.
    Any ideas? Also can the motor be changed without droping the drum?
    Joe
    Apr 2004
    353
    We've had ours seize up once. It wasn't the motor but the bearings were bone dry. If you remove the round plate on the bottom center of the drum, look up and you can see the bearings. The only way we could get any lube on them was to press some grease in there as best we could. There is a nut that you can loosen with a spanner wrench what will back the bearings off a little to help get you moving. Dont forget to re-tighten. It is a pain the the butt job.
    Good luck
    Feb 2009
    8
    Hi, Check the proximity sensors on the far left hand side when the drum is at spindle, there's a small light on the sensor that flashes as each pocket position, if it isn't working, it may be just the sensor, it might be the actual motor that drives the cam and then subsequently the tool drum itself (try cleaning inside the open drum with coolant to ensure the holes nearer the centre of the drum are free from swarf etc (this save all the hassle of dropping the drum tool ring..
    Have had a similar problem several times on my machines before, hope this helps..
    James
    Feb 2009
    5
    Thanks for the insight I did both when it first happened.
    It seams to stall only in one direction. So my sext step is to change the
    relays in the back power box. I hope this works.
    Joe
    Jul 2015
    13
    Re: Tool Drum On Arrow 750
    Quote Originally Posted by Joefizz View Post
    Joe
    Hi Joe, were you able to fix the problem? I am having the same problem getting a one per tool error, do you know wich relays do you need to change?
    Dec 2011
    41
    Once per pocket error is most likely your drum proximity sensor
    David Rogers
    Meadholm Technologies
    Oct 2011
    205
    Joe
    That's what I did when I was having problems. Could have swore it was mechanical because of the thuds and bangs when it indexed one way, Changed the bearings... same problem. Changed the motor...same problem. Finally called 5's and they had me check the relays and one was bad. Problem solved.
    Dec 2006
    584
    Most of the time you need to drop the drum and grease the bearings and the inside index pockets where the Geneva unit engages the drum. It uses a 3 phase motor for the movement and you could have a bad contact on the contactor. There is a separate contactor for each direction, take a meter and check the voltage on each of the 3 legs on each contactor. Should be 230 vac leg to leg or about 115 vac to ground on each leg.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Tool drum 1 search failure!
    By logger in forum Cincinnati CNC
    Last Post: 06-10-2013, 08:39 AM
  2. Arrow 750 tool change/tool carosuel issue
    By Insept in forum Cincinnati CNC
    Last Post: 10-22-2012, 01:31 PM
  3. Auto tool changer Drum type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-18-2012, 09:44 AM
  4. Arrow 500 SK40 Tool Drum Retainer
    By NanoMagnetic in forum Cincinnati CNC
    Last Post: 07-22-2010, 09:55 PM
