Nothing new here. Just another guy trying to decide on a plasma table. After pouring over webs sites for the last 3 weeks I have learned a lot but it's all still a bit overwhelming.
I am looking for a 4x8 table in the 18-25K range.
I will be cutting light gauge alum and steel with the machine. The info I have gathered on alum cutting has varied wildly from manufacture to manufacturer. Some say use nitrogen. An article in the January issue of "the fabricator" mag says to use an argon/nitrogen mix. Most say to just use shop air tho.
I have ruled out several manufacturers for various reasons. Any that have a bolted alum frame are out. Any that uses a hand held torch is out.
I have decided that stepper motors will be fine for my purposes. Plus servos (in most cases) are out of my price range.
Both machines below use 4 steppers and THC.
I took a good look at http://www.trackercnc.com
4x8 $23,390
PROS:
Welded steel frame
True turn-key set up. Thermal Dynamics 80 amp and PC are included
Nice control center that houses flat screen monitor, PC and plasma
Off cutting area parking spot for gantry
They tell me alum cutting is laser quality on shop air
Machine shipped 2wks max (free)
CON'S:
No down draft
No water bed
Closed source system (proprietary)
Haven't been able to find much info on Tracker
I'm leaning toward http://ez-router.com
4x8 $18,250 (depending on options)
Thermal Dynamics 102
PROS:
Price
Lots of options
Stout frame
Gantry that is over-kill for plasma (pro or con?)
Open source system
CON'S:
3-4 week lead time
Over all machine price is good but options are expensive.
Side skirting $2,145. This is just a sheet metal enclosure.
Water bed $4,240...yikes!
I asked if I could just make my own water bed and he said yes but they will charge me $1,750 extra for the frame to accommodate one.
E-chain $734. For plastic cable covers??
I talked to MultiCam. Sounds like a nice machine but I have not got the price list yet. I think it will be out of my price range.
The guy at Dynatorch told me "you don't want to cut alum on our machine". "The edge quality is poor enough that we send ours out to water jet."
No matter tho. They want 33K for their 4x8.
Haven't talked to Shop Sabre yet. They use lead screws so it will probably be out of my budget.
Any input is appreciated. -ted
