using kelling 387 motors with mach 3 and gecko
any help would be apreciated 1:13 lead screw
currently runiing 26000 steps 20 velocity 2 acceleration
iam not sure if thease are correct velocity acceleration step
If you mean a 13tpi lead screw directly driven from the stepper motor,
then you are correct. 26,000 steps per inch with the G540 which is a ten micro step drive. Velocity is what ever you are comfortable with up to the point that the stepper will stall, at which point you back off 10% to be safe. I would say that your acceleration is a little low, but it depends on what you are trying to drive and what results that you are looking for. You will really need to do some trial and error on your machine to make sure it does what you want.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
whats a good starting point for velocity will be cutiing mdf
also what should the other values in motor tuning be set
thanks
Velocity setting has nothing to do with what you are cutting. THAT is controlled by F feed rate. Are you using the G540B xml file downloaded from Gecko?
CR.
yes
how does one change feed rate
is that locked be cad software
Feed rate is set either directly in G code, or in CAM software.
Check this out:
http://www.cnczone.com/forums/showthread.php?t=76865.#3
CR.
