585,737 active members*
4,798 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > best cam for lathe? input being imported solidworks models
    Dec 2008
    21
    Hello all,
    We designers are called "typists" at work (for good reason), and machining is always best left to the real machinists... but I have been having great success these last few weeks learning and milling my own parts using Surfcam. It is a beautifully simple process, straight from a solid model. I've only ruined a few tools, and generated only a small collection of scrap parts... over all, it has been a success.
    The trouble is with turning parts. From what lathe tutorials/documentation I can find (nonexistant in SurfCam "help"), the surfcam lathe process begins with a 2D cross section, not a solid, with a manually 2D sketched stock and clamp. This amount of manual labor is significantly higher than with the mill process.
    Which CAM lathe software can handle an imported solid as is? One that can automatically generate a cross section, give visual of the tool, stock and clamp, and just be friendly to a newbie like me? Are all CAM packages less automated for lathe work? Maybe there is a way in SurfCam that I just haven't found any documentation for?
    Jamison
    Apr 2009
    5
    Esprit
    Check out Esprit at www.dptechnology.com . I used to be in sales and have sold both Surfcam and Esprit. Esprit is by far the winner when it comes to programming a lathe or EDM.
    Alan
    Dec 2008
    21
    Nice.
    http://www.dptechnology.com/en/products_turning.asp
    Now to see the price...
    Thanks Americad
    Apr 2009
    5
    price
    the price is based on how many axis you need. The price used to be about $3000 for 2 axis turning. where are you located?
    Jan 2004
    3154
    Option
    Create a SW drawing.
    Insert a full section view of the part at 1:1 scale.
    Save as DWG or DXF.
    Open in CAM software.
    Pretty quick and easy.
    www.integratedmechanical.ca
  1. Can't use imported DFX or DWG files
    By cijunet in forum GibbsCAM
    Last Post: 10-20-2019, 10:03 PM
  2. CNC diemaking shop needed to build tooling from my SolidWorks models
    By PhoenixMetal in forum Diemaking / Diecutting
    Last Post: 01-19-2011, 04:15 PM
  3. DFX is not imported correctly...
    By ihkim in forum Uncategorised CAM Discussion
    Last Post: 01-07-2010, 06:57 PM
  4. Imported DFX drawings are tiny
    By Mrebeiro70 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2007, 02:22 PM
  5. DXF files imported to Autocad
    By Spitfire in forum Autodesk
    Last Post: 09-27-2006, 03:32 PM
