586,005 active members*
5,181 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Alarm 166- Y return margin too small TM-1
Results 1 to 6 of 6
    Jan 2009
    12
    Have been having alarm 166 (Y return margin too small) error upon zeroing all axis on startup. I have replaced the mechanical Y axis limit switch to no avail. I checked the switch connections for tightness as well as the servo-motor connectors. I have had this problem before and cleaned the limit switch and it solved the problem but not this time. I also checked the arm that contacts the switch to trigger it and it appeared tight and not bent or damaged. Waiting on my HFO to respond but I though I throw this out on the forum to see if anyone has encountered this problem and found the solution. Thanks in advance.
    Robin
    Nov 2003
    236
    If you have replaced the switch then the grid offset should be reset. The value is in encoder counts and should be between 1/8 to 7/8 of a revolution.
    Jan 2009
    12
    Thanks for the quick response! I do not know anything about the grid offset or how to set this. I suppose this is done through parameters and settings. Would you be so kind as to elaborate on how I do this.
    Thanks, Robin A.
    Nov 2003
    236
    This is not really my area of expertise. I would suggest that you call the Haas Factory service department at 805-278-8500 and they should be able to help walk you through it.
    Nov 2003
    236
    Robard,
    I have been told by the service engineer that he tried to send you an email and it did not work. Can you please email me and I will forward his email to you.
    [email protected]
    Jan 2009
    12
    done, thanks
  1. SL-3H 231 232 alarm on zero return
    By TWyatt9 in forum Mori Seiki lathes
    Last Post: 12-05-2008, 09:13 PM
  2. Alarm 167 Zero Ret Margin Too Small
    By lovell110 in forum Haas Mills
    Last Post: 04-01-2008, 06:29 PM
  3. 1st Prob. on my TM-1: Zero return margin too small!
    By KevinWilkins in forum Haas Mills
    Last Post: 02-21-2008, 03:44 PM
  4. Z return margin error
    By Shotout in forum Haas Mills
    Last Post: 10-15-2006, 04:05 PM
  5. help!! x zero ret margin too small?
    By CNChelp in forum Haas Mills
    Last Post: 07-14-2006, 12:56 AM
