Hi, I have a Okuma LB15 MW Lathe with OSP700L controls and I need to program the machine to make 3 slots through 120 degree angle equally spaced which start at the face of the job (Z0) and stop at Z-10.4mm. I believe I have to do this using the Contour Generation Programming Function (SIDE) which carries out arc-form machining on the perihery (side face) of a workpiece by feeding the Z axis while rotating the C axis. I believe the code i need for this is a G132, but that's where i become stuck...I have never used this code before or seen it done. Could some one who has possibly talk me through this process please, and tell me how I go about doing it?
Many thanks in advance!!
