585,917 active members*
3,603 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Partial curves on a surface
Results 1 to 6 of 6
    Feb 2009
    48
    Hi.
    Why is it that sometimes when I create a curve on one edge of a surface the curve doesnt flow along the whole edge and only a small segment is created and are there any ways around this situation other than creating loads of partial curves?
    Many thanks
    Dec 2008
    3109
    You will probably find that where the curve was created was where a mating surface joined.
    Take a cube for example.(surfaces)
    <create curve one edge> will create 1 curve on one edge of the selected surface
    <create curve all edges> will create curves on all edges of the selected surface/s
    Note! creating curves on surfaces that share common edges, you will create curves on both edges, so, there will be double wireframe entities at these edges.
    To avoid this, try creating curves from a solid entity, not from surfaces ( your wireframe will be more accurate and will chain better
    Feb 2009
    48
    That doesnt sound like the problem im experiencing.
    I often copy surfaces onto a new level to create electrodes. Sometimes ill create a curve on one surface and MCAM will create a nice constant curve along the edge and sometimes ill go to create the curve and it will only make a partial curve along the edge despite the fact it was only previously attached to one surface.
    It seems that the more complicated the geometry, the less likely I am to get a decent curve.
    Apr 2009
    23
    I get that too sometimes, I have had that type of problem since version 5 way back when still in DOS. One solution is to use the option to make an edge curve around the whole surface, not just one edge.
    Damo
    Feb 2009
    48
    Yeah...its an option. I just wondered if there were any definitive solutions or tolerance changes I could use.
    Sometimes I just find the less curves you have the easier it is for chaining for trimming and creating new surfaces etc....all the fun stuff with making electrodes using surfaces
    Apr 2009
    23
    Sometimes you just have to do things the hard way. Solids are much easier, but then it's not always possible to have a good solid model to make electrodes from. I find trimming surfaces a bit of a pain sometimes in Mastercam. One other software package that was popular here awhile ago is Powershape. It is very good at trimming surfaces, but then again to do something as simple as sweeping a surface down 2 rails and it couldn't do it. Have fun.
    Damo
  1. Partial Bolt Hole Circle
    By barks in forum Okuma
    Last Post: 11-25-2009, 09:41 AM
  2. Build Question - Partial machine, how do I complete?
    By jross in forum DIY CNC Router Table Machines
    Last Post: 11-04-2008, 01:48 AM
  3. Help programming G2, G3 partial circle blends, radius
    By williamglassII in forum G-Code Programing
    Last Post: 09-24-2007, 11:04 PM
  4. Partial 320?
    By John3 in forum Gecko Drives
    Last Post: 08-11-2007, 06:28 PM
  5. Partial arc
    By positiverake in forum Fanuc
    Last Post: 01-11-2007, 04:29 AM
