585,712 active members*
3,916 visitors online*
    Apr 2009
    4
    Distance Counter
    Greetings,
    I am a first-time poster here and hoping someone can help me figure this out. I would like to be able to log my total cutting distance (in inches) to determine the rate of wear for the bits I am using. The mill machines in our shop have this type of cumulative counter and I'm not sure if Mach3 would differentiate between the rapid and cutting movements. Does anyone know if Mach3 has this feature and if so where it is and how to use it? I wonder if perhaps I just don't know the right term for it...
    Thanks!
    -JC
    Jul 2006
    1062
    Open Mach3 and select "Operator" on the toolbar and check the maintenance section....it has way too much information
    Keith
    Apr 2009
    4
    Thanks, that is a lot of info!
    JC
  1. Distance rings?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 05-30-2012, 02:46 AM
  2. distance z axis can travel
    By mostlund in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:04 AM
  3. Bearing distance
    By pyrojon in forum DIY CNC Router Table Machines
    Last Post: 05-23-2005, 01:51 PM
  4. What's your max distance to encoder?
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 05-12-2005, 04:57 PM
  5. Travel distance is inaccurate.
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-15-2004, 03:32 PM
