584,849 active members*
4,391 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > Powermill Post Processors
Page 1 of 3 123
Results 1 to 20 of 56
    May 2003
    267
    What is the difference between Delcam's Duct-Post and PM-Post? Is one a subset of the other? Which one do I need to look at to convert Powermill toolpaths to and NC file?
    Thanks,
    Oct 2008
    13
    There is no difference for converting toolpaths. Delcam's duct-post is the default machine post processor where you can make some changes. In the PM-Post you can create the same post processor as the default one but also you can create a completely new post processor
    May 2003
    267
    A friend of mine found a Powermill Post Processor option file that works between Powermill and Mach3 mill.
    Use at your own risk since I did not try out all of the features in it. But, I did try it out and it does work for me.
    The post processor option file is attached.
    Thanks,
    Attached Files Attached Files
    Jan 2007
    7
    I for Mach2 a pos-pm at the post but I can not coverter for the pmopt opt.
    Solutions? :drowning:
    Mar 2023
    Re: Powermill Post Processors
    Would you please send me ?
    Post processor power mill with dmu 60p
    May 2003
    267
    PowerMill Post Processor for Mach3
    I am uploading an updated version of the PowerMill Post Processor option file for Mach3. In the older version that I posted on this thread, a G28 command was used that will use the Machine Coords to go to X0Y0Z0 which messed me up sometimes. This new version no longer uses G28. Instead, I had the Z height increase to move the tool bit out of the work area at the end of the gcode file.
    Also, use this Post Processor option file at your own risk since I will not be responsible for anything.
    However, I do personally use it myself.
    Thanks,
    May 2003
    267
    Here is an updated PowerMill Post processor. It was modified using Delcam's PM Post Processor 4.7.00. I performed simple tests using PowerMill 2010 and Mach3.
    This version is for Mach3 controller and fixes some of the IJK coordinates system (now uses absolute rather than incremental values). There are some other changes to make things work as expected.
    Again as always, use this at your own risk. I cannot be responsible for anything.
    Jun 2012
    .i have made a tool path for CNC machine for milling operation, so that i can run the machine and finally made my component....but now i want to do simulation of that process.
    my problem is that i want to extract the Co-ordinates value in tabular form from the power software. but i dont know how can i??
    Could u plz help me in this?
    Oct 2019
    Plz snd if u hve Post processer of PM for fanuc 10mm
    Feb 2011
    212
    good question you might have better luck at the Delcam forum
    May 2003
    267
    I did not see a Mach3 post processor on the Delcam forums site. If someone sees it, can they please provide a link or post it on this site?
    Mar 2010
    post .opt to .pmopt
    Hey can some body help me with conveting a .opt post to .pmopt.
    May 2008
    PMOPT does not outputs G0 as G1
    My current .pmopt outputs my rapid moves as G1 instead of G0.
    Any one knows what part of the .pmopt I need to tweak to get G0 outputs for my rapid moves
    Jun 2012
    Edit/Delete Message
    Nov 2009
    3
    Re: post .opt to .pmopt
    Hello, im very interested in make a postprocessor for EMC2. My machine have 3 axis and kress spindle...
    I use powermill 2011 and opt file.
    Can anybody help me to find anyone that fit my machine? or... what can i do to use powemill?
    thanks a lot
    Nov 2013
    Lightbulb Post processor-MACH 3
    I need the post processor for mach3 controller linking with the power mill 2010/2012.
    can any body knows how to build the post processor for a specific machine controller or to generate.
    Thanks in advance..!!
    please help
    Nov 2007
    45
    if anyone is interested I have a post for a fanuc18i MB - in the old *.opt format
    May 2016
    Quote Originally Posted by anilam View Post
    Yes I'm in search of this post processor can you help me?
    Nov 2007
    45
    Quote Originally Posted by chiragrrao View Post
    I'll pm you on monday when I'm back at work.
    the post is old and written for PM7
    Dec 2013
    is there anyone who can provide 4 axis post processor (.opt) file for delcam, fannuc machine is the machine i have
Page 1 of 3 123
  1. post processors
    By Alisson Felipe in forum EdgeCam
    Last Post: 10-29-2010, 02:11 PM
  2. Post Processors
    By spark14 in forum Want To Buy...Need help!
    Last Post: 03-10-2010, 01:26 PM
  3. What are post processors?
    By raworkshop in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2009, 12:10 PM
  4. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
