585,975 active members*
4,957 visitors online*
Results 1 to 8 of 8
    Oct 2007
    33
    Combined limit/home switch config...
    I am trying to get a combined limit/home switch configuration working, however when I 'home' the axis, it ends up tripping the limit switch as well...
    is there something special I need to do to get it to jog back of the switch after it homes the axis?
    I looked on the documentation wiki, and couldn't find anything relating to this probably very common issue, so I assume it's an easy fix that's just beyond me.
    Thanks!
    -J
    Oct 2008
    78
    I think your looking for "HOME_IGNORE_LIMITS" in your INI file set it to yes
    Donnie
    Oct 2007
    33
    I set that to yes... but I'm still getting the limit/joint following error...
    -J
    Feb 2007
    514
    You might have the direction or something like that wrong. Try posting this in one of the EMC community contact methods as most EMC folks don't hang out on the Zone. For the fastest help hop on the #emc channel on this page http://www.linuxcnc.org/content/view/4/8/lang,en/
    John
    Mar 2004
    1806
    I cannot respond directly to EMC, but when I set it up in Turbocnc, I CANNOT setup the limits! If I set homeaslimits, then they will act as limits or home as appropriate.
    The first time I set mine up, I also setup limits and had the results that you are having.
    Art
    AKA Country Bubba (Older Than Dirt)
    Apr 2005
    1778
    Quote Originally Posted by jvanick View Post
    -J
    I use combined home and limit switches, one switch at each end of travel.
    OK, one question. Is it just one switch for home and limit at that end of the travel?
    Here is what I did in my ".hal" file.
    # create a signal for the limit switches
    net both-home-x <= parport.0.pin-11-in
    net both-home-y <= parport.0.pin-12-in
    net both-home-z <= parport.0.pin-13-in
    net both-home-x => axis.0.neg-lim-sw-in axis.0.pos-lim-sw-in axis.0.home-sw-in
    net both-home-y => axis.1.neg-lim-sw-in axis.1.pos-lim-sw-in axis.1.home-sw-in
    net both-home-z => axis.2.neg-lim-sw-in axis.2.pos-lim-sw-in axis.2.home-sw-in
    And here are the settings for the X-axis in my ".ini" file.
    HOME_OFFSET = -0.1
    HOME_SEARCH_VEL = -1.500
    HOME_LATCH_VEL = 0.250
    HOME_USE_INDEX = NO
    HOME_IGNORE_LIMITS = YES
    HOME_SEQUENCE = 1
    I am homing at the zero end of travel, using 60ipm travel velocity and I move 0.1" off of the switch to set axis zero.
    Alan
    Oct 2008
    78
    -J
    Is your system a stepper or servo? If a servo then your scaling is off or the the tuning is to far off. If a stepper then contact the mailing list at [email protected].
    Oct 2007
    33
    it is a stepper system, but I have to say that I feel like a total moron.
    I had a typo in my HOME_IGNORE_LIMITS line.. doh.
    anyways, it's working perfectly now.
    thanks for the help guys!
    -J
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
