521,885 active members*
1,817 visitors online*
IndustryArena Forum > CAD Software > SolidEdge > Looking for first inspection article inspection software
Results 1 to 3 of 3
    Registered
    Apr 2005
    81
    Hopefully someone can help me out, I am trying to find a software package that helps generates first article inspection sheets. Currently we are doing this manually in excel and it just is not the best way. Any suggestions on software that either imports solidedge files or is integrated into solidedge? I have seen a package called Inspectionxpert that ties into solidworks and looks great but of course it doesn't play quite as well well with Solidedge. Any suggestions are welcome, we are just trying to find a better way.
    Look forward to the responses.
    Member
    Jun 2015
    3076
    Re: Looking for first inspection article inspection software
    hy a bit late, i know ... i posted a thread somewhere and this was inside the "similar threads list"
    i can not give you a straight answer to your question ... i only can say this : in mechanics i encounter technical drawings with dimensions auto-generated
    1) dimensions are not always right, generally because cad users have no clue about how that part will work, and in the end is a "futuristic design" that is harder to craft, because it was designded without knowing how the part is done cad & technology must go hand in hand, so to say
    2) autogenerated tolerances again, a big wall : because they require more precision where actually is not required, thus more machining for nothing, and also they may miss the critical dimension chain that makes the part work
    so an inspection list should be dependant on crafting technology
    knowing cad and knowing technology is not always a lucky combination inside someone
    but, there are big chances for "knowing / mastering" one & "understanding" the other, like active inside one domain and passive inside another ... this skill combination has more chances to be inside someone
    pls find attached an inspection list for machining mass production parts on cnc
    also, if you wish, please share the inspection list "your way" kindly !
    Member
    Jun 2015
    3076
    one more thing, also about mechanical parts ( at least ) : after part sketch / solid is ok, the technology for crafting it is written inside a manual, that contains a lot of intermediate techincal drawings, with fixtures recomandations, tools and intermediate control, accepted deviations, and others
    this allows fast implementation, and the "inspection list" is contained inside this manual ... this is the "cherry on top"
    few dare changing such documents, because this involves knowing the overall scene
    i just found this; hope it helps :
    https://www.youtube.com/watch?v=y2vGl7zg3oY
  1. Used Tormach Inspection
    By luv2ride in forum Tormach Personal CNC Mill
    Last Post: 03-28-2014, 08:11 PM
  2. Replies: 12
    Last Post: 10-12-2012, 10:39 PM
  3. inspection plus
    By CLATHAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-27-2011, 05:13 AM
  4. Inspection software. Operator self inspection
    By Maddehn in forum General MetalWork Discussion
    Last Post: 08-23-2010, 10:02 PM
  5. Inspection question
    By LeeinFl in forum General MetalWork Discussion
    Last Post: 09-23-2009, 02:22 AM
