585,969 active members*
4,573 visitors online*
    Nov 2004
    139
    CNC4PC MPG pendent + C22 setup
    Hi everyone,
    Here is another thread from me, hope you can help. I'm new to MAch3 so go easy on me.
    I bought a MPG pendent + C22 adaptor for LPT2 from CNC4PC, had the adaptor connected to LPT2, followed this link for setups:
    http://www.cnc4pc.com/Tech_Docs/guid..._over_LPT2.htm
    LPT 2 and LPt 3 = Sunix 4018a 2 ports Parallel Universal PCI Board ( http://www.sunix.com.tw/it/en/Produc...a_id=0&sid=479)
    In Mach 3 ----->Config ------> Ports and Pin :
    enabled Port #1 = 0378 (port address)
    enabled Port #2 = the LPT 2 port address,
    To check the LPT 2 port address ----> Device manager ------> Ports (com & LPT) ----> PCI EPP/ECP Parallel Port (LPT2)-----> Resources ------> SNXPCARD_ENUM\SNXPCARD_PARPECP\1409&7268_01041409_00F0_PORT1
    What should I put in the LPT 2port address in Mach 3? is it 00F0? or...
    Freddy
    Nov 2004
    139
    Problem solved!!, Change the Pararell PCI card to another brand that uses Moschip.
  1. DSP pendent -how it works?
    By Fonfon in forum Open Source Controller Boards
    Last Post: 02-28-2009, 08:06 PM
  2. CNC4PC C6 Speed Controller setup?
    By vlmarshall in forum LinuxCNC (formerly EMC2)
    Last Post: 02-23-2009, 12:39 PM
  3. cnc4pc pendent
    By davidponte in forum Mach Mill
    Last Post: 12-26-2008, 07:28 AM
  4. Xylotex and CNC4PC setup with mach3
    By bruno123 in forum Xylotex
    Last Post: 05-03-2007, 06:08 AM
