585,978 active members*
4,337 visitors online*
Results 1 to 9 of 9
    Apr 2009
    20
    controlling chinese laser power supply
    I am currently retrofitting a cheap chinese laser with new driver boards so i don't have to use their moshi draw program. i have now got the x,y working fine and am looking to connect the laser board. before i fry my computer i am just trying to find somone who can help me out.
    i have attached a photo of my board
    w }
    r }-these go to potentiometer on control panel to control laser power
    w }
    k both k's are test button control
    k
    grd originally went to main driver control board
    +5v
    i currently have both grd and +5v disconnected and the laser still test fires by test button.
    k,k and grd,5v both lead to 2x opto coupler on the laser board. i'm not sure the best way to connect the laser to my breakout board to control using pwm on mach3. i think it used to use the grd and +5v.
    if you could point me in the correct direction on what connections to make.
    Dominic,
    Dec 2008
    1258
    Not sure if you have an answer or not, but these may help:
    http://www.routoutcnc.co.uk/Forum/index.php?topic=17.0
    http://alastair.d-silva.org/working-...aser-engravers
    I haven't tried driving it directly as I'm happy with Newlydraw.
    Zax.
    Jun 2007
    74
    The original interface card puts out 5V on the "LASER" line to drive the front end of the optocoupler. You can hook this line to your breakout instead. If your breakout can't drive 5V, then you can pull it up with about 150 ohms and use a pulldown in your breakout to drive it in an inverted mode.
    What I'm trying to say but finding it difficult is that I believe the optocoupler front end already has a built in current limiting resistor. You can drive it with 5V without a problem.
    I hooked mine directly to the parallel port of the computer without issue, but this was my risk, not yours. I don't use a breakout board for my interface.
    Apr 2009
    20
    controlling pwm laser board
    thanks for your help. yes i can now control my laser using the grd and +5v to the breakout board. the x, y works fine and i can cut at a constant power. i am using mach3 and now want to try and get the pwm to work as i can only cut at the power specified on the control panel on the laser cutter.
    can anyone give me a clue on the best way to wire up instead of this potentiometer on the control panel instead to my breakout board. there are 3 wires that i think i need to connect and also how to control it in mach3.
    i think i have an idea about setting the spindle speed to 100 and then i should be able to set the % but i'm not sure.
    if you need any photos of the wiring i would be very greatful as i have changed a low powered chinese engraver to a very powerful cutter which if anything is too powerful and cuts to quickly for my needs and would like to be able to lower the power to engrave again.
    Dominic
    Jun 2007
    74
    I have not played with the PWM features yet, but I can say the easiest thing to do for simple cutting is to wire your laser ON-OFF to the Z axis direction bit and program the Z axis speed to be maximum within the motor settings.
    In this scenario, a standard G code written for milling will fire the laser when it has "dropped the milling bit" and turn off the laser when it is retracted. This assumes you are only doing milling without varying degrees of z depth.
    Jun 2014
    Re: controlling chinese laser power supply
    Hi there,
    It turns out I have the exact same type of power supply, with connectors W,R,W,K,K,G,5v
    Did you manage to control this through a PWM? (direct connection or analog-digital conversion?)
    Should I simply order a new power supply?
    Thanks!
    Jun 2007
    74
    The supply you have is fine. Pwm changes the power because there is an rc circuit inside the supply. Note this is slow though. You will set a constant power level and then toun laser on and off rapidly. All your questions are answered at buildlog.net. you can see some of my engravings there too.
    Jun 2014
    Great, thanks - My question originated from the fact that most power supplies seem to have a connector of the type TH TL WP G IN 5v (and explicitly state the use of a PWM), whereas mine has a different connector (W R W K K G 5), which seems relatively rare.
    I understand how the PWM signal can be converted to a voltage by a RC circuit ; I am just worried that my power supply would perhaps not be equipped with this? (but of course I could add it externally, if required).
    I guess that if the change of power is slow I will have to decompose smooth gradient surfaces into curves of a same power level, and switch in between.
    Thanks!
    Apr 2009
    20
    I use the laser regularly now but still mostly for vector work. I don't use pwm but still change power via the pot.
    the stages I use are
    inkscape for bmp or jpeg to vector trace tool if copying image
    coral or autocad to tidy vectors/add text lines or cut outs
    then into aspire and i group each cut power into a separate job, export the gcode but use the post process from "buildlog" (thanks its fantastic to prevent delay during start up and burning a dot)
    then mach3 to run the gcode
    the laser is linked to z movement but with the buildlog post process there is no delay and the cut quality increased massively.
    when I raster images i often use mach3 and then overlay the vector cuts after. I was thinking of saving up for dsp controller but waiting for the £300 spare and someone to show me its worth the cost.
    I will add some photos of my results when I am on the other computer.
  1. Replies: 6
    Last Post: 10-28-2014, 10:51 AM
  2. GW LC 1290 Laser Power Supply Not out puting power
    By cnarch in forum G.Weike Laser
    Last Post: 11-25-2013, 05:26 AM
  3. Simple wiring question (chinese power supply)
    By rhexis in forum Hobby Discussion
    Last Post: 08-28-2010, 02:52 PM
  4. Chinese Power Supply connections
    By thudson in forum CNC Machine Related Electronics
    Last Post: 03-20-2010, 04:29 AM
  5. Chinese laser. power suggestion
    By salmve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-30-2009, 09:36 PM
