586,024 active members*
4,420 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > Configuration of Fourth Axis Configuration(Rotation of 360 degree z Axis)
    Feb 2009
    Hello to everybody!!
    I’m a new user of emc2 and I hope somebody can help me with the configuration of fourth axis.
    Infact I build mine new small machine with the 3 canonical axis X,Y,Z and now I wold like do an upgrade to move Z axis with rotation of 360 degree.
    Pratically I wold like use a whell in diamant for engrave flat marble and with it following the engrave with lines and arcs.
    Using the emc2’s wizard (Ver2.0.8) I configurate the fourth axis (A)and in jog mode I can move it perfectly about rotation in clockwise and CCW directions.
    Mine question is:
    After build mine draw in dxf with Autocad for example, wich CAM I must use for save mine file with the right code for the fourth axis?
    Or is necessary some differents configurations?
    Please if somebody can Help me I will appreciate a Lot!!
    Very Thanks for Your Help!!!
    Kind Regards Luciano.
    Attached Files Attached Files
    May 2010
    18
    You may want to try a formula in Excel to transform your X or Y into an angle...
  1. Question About 4th Axis Configuration
    By Khalid in forum DIY CNC Router Table Machines
    Last Post: 02-27-2009, 06:52 PM
  2. 3 axis mill with pluto-servo configuration help need
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 02-28-2008, 07:23 PM
  3. HELP: 4th Axis configuration (video posted)
    By PEU in forum Syil Products
    Last Post: 12-14-2007, 09:57 PM
  4. Axis configuration, please help.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 06-25-2007, 11:38 AM
  5. Need help with axis configuration
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 11:06 AM
