585,954 active members*
4,559 visitors online*
Thread: turret issue
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Feb 2013
    788
    Re: turret issue
    Quote Originally Posted by metalrelated View Post
    Markjb I have the same lathe and still have the issue, I cant seem to reset the alarm, any suggestions? or can you help me get a step by step guide. Thank you
    See the post that matches the following quote. It has a procedure for each alarm... approximately 8 posts back...
    Quote Originally Posted by dhardt View Post
    Take a look at the Troubleshooting section for each alarm, attached.
    Check out the action on the proximity switch for the DOG.
    Is the DOG rod "sluggish"? (it might need disassembly and cleaning or replace)
    Is the proximity switch dirty or out of alignment?
    Read the attached sections and check any other items mentioned, also.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
  2. #22
    Jan 2011
    Re: turret issue
    Anyone have the process to reset the 2047 Alarm. Need the Pro-Motion Servo step by step re-set. K5.4 is set to 0 but turret will not rotate by hand or by control button. Battery was dead, replaced it and 2047 continues. ALP-En on servo control readout.
  3. #23
    Feb 2013
    788
    Quote Originally Posted by FastMachining View Post
    K5.4 set to 0 turns OFF the manual override.
    To manually actuate turret unclamp...set K5.4 to 1 ( it should then turn by hand)
  4. #24
    Jul 2018
    Can someone please tell me if I'm having a backlash issue. Put new servo motor on for the turret. T1 - T4 change no problem but gets a timeout alarm when changing tool's across from t1. T5,t6,t7 t8. Is this 48-51 parameters for servo.
  5. #25
    Sep 2020
    Re: turret issue
    This helped some but still have the error periodically. Swapped battery in servo. Not sure how to reset parameter #8 on promo unit. Any help? Could this be my problem? However, the alarm won't go away and I can't get it to rotate using the turret switch on the control. Where would I find the DOG and turret sensor on my machine? also check virtual credit card for netflix
Page 2 of 2 12
  1. Daewoo Puma 230 Turret issue
    By atscnc in forum Daewoo/Doosan
    Last Post: 02-04-2022, 01:53 AM
  2. QT28 turret issue
    By Paul in OK in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-05-2012, 10:37 PM
  3. Servo Turret Issue
    By Tom Slick in forum Fadal
    Last Post: 03-03-2008, 05:34 PM
  4. Leadwell GTC-20 turret issue
    By hutch07 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-14-2007, 03:23 PM
  5. another turret issue
    By Paul in OK in forum Daewoo/Doosan
    Last Post: 05-24-2007, 05:21 PM
